Spout connector - Mustang Evolution
Old 09-29-2011, 03:51 PM   #1
86gt's Avatar
Spout connector
Would there be any reason to leave out the spout connector? I just noticed it wasn't there... And would that cause a drivability problem?
---------- Post added at 04:51 PM ---------- Previous post was at 04:40 PM ----------
I'm hoping it's as easy as a new one to fix my baby!!!
86gt is offline   Reply With Quote
Old 09-29-2011, 03:53 PM   #2
Travis B's Avatar
I know this is a stupid question but I just bought a mustang so I am very new. What is the spout connector?
Travis B is offline   Reply With Quote
Old 09-29-2011, 04:04 PM   #3
86gt's Avatar
It's a little plug on the wires going to the distributor and controls the timing through the computer...all I know for sure is that it must be removed in order to set base timing because if it's not the computer will adjust accordingly!
Old 09-29-2011, 04:18 PM   #4
93slowstang's Avatar
Re: Spout connector
+1, and some people advance their car and leave it out. I dont really see the point it doing that, but it shouldn't hurt your car with it out.
---------- Post added at 05:18 PM ---------- Previous post was at 05:15 PM ----------
It may cause some drivability problems in a speed density car.
Old 10-01-2011, 11:30 AM   #5
Titus Wadicus
svtlx's Avatar
Re: Spout connector
there is no reason to not run the spout connector... not a good one anyway. go to the junk yard and get one.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 10-01-2011, 11:40 AM   #6
86gt's Avatar
Thanks...I'll get one!
Old 10-01-2011, 11:42 AM   #7
Titus Wadicus
svtlx's Avatar
Re: Spout connector
it will start better, idle better, and fuel milage pick up a tiny bit. throttle response too. do you know where your timing is currently set?
Old 10-01-2011, 03:50 PM   #8
86gt's Avatar
I have no idea...and don't have a timing light at the moment! I have a no start condition I have to work on now for some reason that I need to fix!
04:46 AM
