I Need some help? - Mustang Evolution
Old 09-29-2011, 05:13 PM   #1
WhiteCobra94's Avatar
I Need some help?
I'm in the process of ripping out the motor in my car for my new one and as I do I matching up what goes where in all my new stuff and on my stock upper manifold is .....? Idk what it's called!
ID:	32236   Click image for larger version
Old 09-29-2011, 05:17 PM   #2
A nipple . It s where the booster for the brakes get ita vacuum and and areas that need vacu
tbonestang is offline   Reply With Quote
Old 09-29-2011, 06:41 PM   #3
Well my issue is , is looks like where the threads are , are 1/2 (I think) and on my new intake the hole to thread I to looks 3/8 (I think) so I'm trying to find a new one for my intake !!
Old 09-29-2011, 07:14 PM   #4
Check the vendor who support this site
Old 09-29-2011, 11:33 PM   #5
86gt's Avatar
And if you are unable to get one from one of the vendors, I would suggest a junk yard depending on what manifold you're going with?!
86gt is offline   Reply With Quote
Old 09-30-2011, 04:53 AM   #6
Well I'm going with the Edelbrock 5.0 Performer Intake manifold and the thread holes are smaller then the stock ones!
Old 09-30-2011, 08:14 AM   #7
Re: I Need some help?
Is it new?
They usually furnish at least some of the fittings you will need if they are different from stock.
Your other choices are:
Drill and retap the hole to fit the fitting you have.
Adapt the fitting down to the size you need with a 1/2"x 3/8" pipe reducer and 3/8" nipple.
Or hope you get lucky and find what you need at an auto parts store or salvage yard.
Old 09-30-2011, 08:15 AM   #8
86gt's Avatar
In that case, I bet a Lowe's or Home depot might have a reducer or bung in their pluming department!
Hope that helps...
Old 09-30-2011, 04:46 PM   #9
just remember that you did that incase you run into insufficient vavuum problem down the road . i would think you might lose a little volume on your vacuum.most likely not because your after market intake might create more vacuume than your stock one.just something to keep in mind.
Old 10-01-2011, 11:11 AM   #10
Titus Wadicus
svtlx's Avatar
any parts store with a "help" section has them or hardware store. they arent hard to find at all. dont worry bout nipple sizes... the only one u need to pay attention to is the brake booster hose. the others arent critical, as long as they got sum sort of vacuum you will be fine
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 10-01-2011, 11:54 AM   #11
Ok cool thanks guys!!!
06:33 AM
