Project - Page 2 - Mustang Evolution
Old 10-19-2011, 05:59 PM   #36
NeedSomeMods's Avatar
Update:
After some further overheating issues, I finally changed radiators.
With that, I'm going to go ahead and say that the swap is complete. Still working out a few bugs, but it's all there.
I have a feeling that this car will always be a project; one that I will continue to enjoy!
Thanks all for your help and support.
If I have any more questions I'll just start a new thread, as I already have.. Haha
---------- Post added at 06:59 PM ---------- Previous post was at 06:59 PM ----------
More pics to come when I get on a computer.
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 10-20-2011, 01:18 AM   #37
Re: Project
Originally Posted by NeedSomeMods View Post
Update:
Glad to hear you are getting it sorted out.
Yes, they are "always a project". That's what makes them so much fun to own and tinker with.
Old 10-24-2011, 08:23 AM   #38
Titus Wadicus
svtlx's Avatar
Re: Project
Originally Posted by Kyle94GT302 View Post
You will defiantly want to get a dyno tune cause the 94-95 ecu's don't like mods such as a cam and not having the egr plugged up and working properly the 94-95 ecu's are awesome for tuning have a lot of different perimeters you can tune for and when you get it tuned they can delete the egr system out of the equation! Dyno tune would be the best so you can get the most power and best drivability out of you set-up! I have a 94 gt myself and about to get it dyno tuned and my egr is removed as well and the check engine light comes on on me and I am getting tired of that little light being on haha
you need to get an egr simulator. i got mine from ebay for like 18 buks. plugs into the egr harness, and keeps the cel off. not to mention the car runs better cause the egr isnt in open loop which will effect your overall fuel mapping
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 10-24-2011, 08:37 AM   #39
deadsp0t's Avatar
Wish I had known that way back when, had caps on the tubes and just lived around the CEL
That's unimpressive
Old 10-24-2011, 09:00 AM   #40
Titus Wadicus
svtlx's Avatar
Re: Project
you still gotta cap and disconnect the egr components. it just cures the open loop problem with the pcm. which helps your idle and general fuel mapping up to about 2800rpm or so. i learned bout them a long time ago. i disconeected mine and it ran like pure shiiiit. so then i reconnected the sensor, and then learned bout the simulator.
again, you can still reconnect the sensor to the plug and let it dangle on the intake just to get it to run and idle better till u get a simulator. while still having the rest of the egr components disconnected
im running foxbody headers and exhaust on my 97, so i understand
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
my project 5.0 C4king Pictures and Videos 6 08-01-2011 09:36 PM
10:27 PM
