trouble shooting - Mustang Evolution
Old 10-02-2011, 06:32 AM   #1
mystang50's Avatar
trouble shooting
has anyone on here experienced a bad spark plug wire but where it dont miss but it pings...(well best way to describe sound is rocks shaking in a tin can) when i romp on it when it is hot outside...this has been happing for long time a whole year or so...timing is advanced cuz freind thought that was mabye prob but no, while running tha high octane gas........or it could posibly be running lean??the senser that screws into cai inlet tube dont have teflon tape..or any kind of sealer..but not to losse but could air still creep in there..it dont knock like that every day jus some days it does it some dont..only does it when in high rpm when gas pedel is stuck to floor..and it also seems like when its pinging it aint at full potential...
---------- Post added at 07:32 AM ---------- Previous post was at 07:28 AM ----------
i did replace wires awhile ago and romped the hell out of it and didnt do it...later that day took it jus for a cruise and it started missing, one fell of and got melted on boot and on wire but not exposed..what do yall suggest?? change wires and seal that sensor? and hopefully that'll fix it.......cant really explain sound but pretty close to what i explaind...i did to try to recode sound but car in general is to loud...:>...
Old 10-02-2011, 07:55 AM   #2
Re: trouble shooting
Your timing is advanced to far.
Eventually you will burn a hole in a piston if you leave it that way.
I would reset the timing to less advance as soon as possible.
Try 2 degrees less than what it is now.
Old 10-02-2011, 07:59 AM   #3
mystang50's Avatar
no i dont think so...it did it befor we advance it...didnt advacne it too far
Old 10-02-2011, 08:04 AM   #4
Yes it is advanced to far.
What you are hearing is detonation or preignition of the fuel mixture.
If you advanced it even more, then you made it worse.
Even 1-2 degrees can make a difference.
Your car do what you wish.
Old 10-02-2011, 09:32 AM   #5
mystang50's Avatar
if timing was to far wouldnt it do it all the time??
Old 10-02-2011, 09:40 AM   #6
jhagan1980's Avatar
My $ is on TH. He's pretty sharp.
jhagan1980 is offline   Reply With Quote
Old 10-02-2011, 11:58 AM   #7
Not necessarily.
Different air temperature and humidity levels could make enough difference.
Old 10-02-2011, 11:58 AM   #8
Thanks for the support.
Old 10-02-2011, 12:16 PM   #9
Beav's Avatar
I agree, it is too far advanced. There is no way you should have advanced the timing when it was already pinging. Pinging will eventually destroy an engine, you really need to solve this...
T M has given you excellent advice...
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 10-02-2011, 01:13 PM   #10
T H has given you excellent advice...
Thanks for the verification and backing me up.
Old 10-03-2011, 10:52 PM   #11
94 Mustang GT's Avatar
I agree it's too advanced (I did that with my mustang but disnt have a timing light so set it by ear bad idea i know then it started making similar noise so I out premium in it and it stopped just been too lazy to bring it back down) You can have other bad things happen then just burn a hole in the piston!!
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 10-04-2011, 03:28 AM   #12
deadsp0t's Avatar
There should be marks, line them back up... Like.. Last year!! You'll be shopping rebuild kits soon...
That's unimpressive
A/C trouble Exodus1021 2011-2014 Mustang GT 2 10-12-2011 03:09 PM
DTC Trouble MustangMafia97 1996-2004 Mustang GT 11 10-02-2011 08:31 PM
Rear end trouble Dgerow12 Pre-2005 V6 Mustang 15 09-08-2011 03:59 AM
Display pic trouble shazzsk89 General Car Discussion 1 08-20-2011 10:04 AM
Engine trouble! 99ford 2005-2010 V6 Mustang 7 08-02-2011 11:52 PM
03:14 PM
