speedometer problems - Mustang Evolution
Old 10-05-2011, 11:12 PM   #1
Qwik Four Six's Avatar
Alright I took everything off to get the speedometer off. Two wires from tge right hand side on the panel for the emergency flashers and for the rear defeoster came off, and there's 3 holes. I'll figure that out. But anyway, my speedometer cable wasn't connected to the speedometer. It's an 89. Does it just slide on to the back? Is it supposed to click on? How's is the cable supposed to stay connected?? It's an 89 coupe 4 cyl car with a 5.0.
Qwik Four Six is offline   Reply With Quote
Old 10-06-2011, 02:13 AM   #2
89 Foxloco's Avatar
It just stays on..no click.I had the same problem.but theirs no click..just right before you start putting the screws on. make sure its all the way in..and it will work perfectly.
89 Foxloco is offline   Reply With Quote
Old 10-06-2011, 06:04 AM   #3
Alright. I hope. Thanks man. I tried last night and then went up the driveway and it didn't work. So I pulled the little white piece a little bit out of it's cover and then put it into the speedometer. I'm about to go see if it works. Thanks.
Old 10-06-2011, 07:58 AM   #4
I pulled the cable out of it's surrounding cover a little bit, and I can't pul the cable back into the cover. I'll try it later. But the little white piece that goes into the speedo is completely smooth, not notched or anything. So how is it supposed to spin the speedometer?
Old 10-06-2011, 08:01 AM   #5
Re: speedometer problems
There should be a catch that locks into place when you push the cable onto the back of the speedometer. Once it has latched into place you shouldn't be able to pull it off without pressing on the side of the catch.
Look for a replacement speedo cable on American Muscle or LRS and you will see what I am talking about.
Old 10-06-2011, 08:26 AM   #6
There kinda like a white latch on the cable, but nothing for the piece to latch onto, on the back of the speedometer.
Old 10-06-2011, 04:13 PM   #7
I pulled the little white piece out of the cover this morning and now it's stickin about an inch out. I can't get it to go back in..what should I do? Is there a way I can get it back in somehow??
Old 10-06-2011, 09:39 PM   #8
Bump
Old 10-07-2011, 07:25 AM   #9
The cover of what? The speedo cable or the speedometer itself?
Old 10-07-2011, 07:27 AM   #10
There is an indentation (ring) around the speedometer connection that the latch hooks into.
Old 10-07-2011, 07:42 AM   #11
I see it. But the problem now is that the cable is too far out now. Anyway I can get it back in?
---------- Post added at 09:42 AM ---------- Previous post was at 09:41 AM ----------
Yes. The cover on the cable.
Old 10-07-2011, 07:48 AM   #12
You might try heating it with a hair dryer or immersing it in hot water to make it easier to slip back into place.
Old 10-07-2011, 07:50 AM   #13
Does that mean I have to take the whole cable out out the car..?
Old 10-07-2011, 08:07 AM   #14
If you cannot get to it with a hair dryer, then yes you will probably have to.
You might try removing the gauge cluster first and see if you can get to it from there.
At any rate, if you can't get it back into place, you will have to replace it and if it is already out the job is half done.
Old 10-07-2011, 09:17 AM   #15
Well...the cluster and everything was out, but I put it back together yesterday. Ima wait until I get a new cluster to replace the cable also.
Old 10-07-2011, 09:28 PM   #16
Sounds sensible to me.
Good luck.
Self installing the boss 302 mani! Any advice or problems anyone has run into? Benzo 2011-2014 Mustang GT 6 10-03-2011 05:23 PM
Speedometer help! 89 Foxloco 1979-1995 Mustang GT 13 08-07-2011 05:23 PM
Different Starting Problems milkrun49 2011-2014 Mustang GT 3 07-15-2011 02:19 PM
Free saleen speedometer Qwik Four Six 1979-1995 Mustang GT 12 06-25-2011 05:05 PM
12:57 AM
