1990 gt all black - Mustang Evolution
Old 10-06-2011, 10:35 AM   #1
04machazblue's Avatar
1990 gt all black
Okay guys need some advice I am going to look at foxbody today it has a stroked 351w stroked to 383! It has a cam and other little bolt ons. Wondering if there is anything I'n foxbodys that go or any certain area were the body rots any info be nice
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 10-06-2011, 12:27 PM   #2
93slowstang's Avatar
Door jamb right behind the fenders. At least it's a problem I have to address on mine.
Old 10-06-2011, 12:37 PM   #3
deadsp0t's Avatar
Battery tray area on both sides in the engine compartment. I've seen some that look awful under the battery...
That's unimpressive
Old 10-06-2011, 03:09 PM   #4
Floor pans
Old 10-06-2011, 03:38 PM   #5
Originally Posted by dreamstang
Floor pans
Well I am
Leaving to go look at it soon will have some pictures up
Old 10-07-2011, 08:33 AM   #6
Titus Wadicus
svtlx's Avatar
Re: 1990 gt all black
pretty much as stated above. definatley check the shock towers
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 10-07-2011, 09:27 AM   #7
Went and looked at it wasn't what I wanted. But I got a couple lined up to look at going to look at a 93 lx with gt40 heads has aftermarket roller rockers and gt40 upper and lower intake and a e303 cam and all the supporting mods not a bad start.
Matte black or gloss black? Srohda 2011-2014 Mustang GT 17 10-28-2011 08:38 AM
Red or Black? cruisin99coupe Mustang Paint, Appearance & Detailing 18 09-30-2011 01:17 AM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
1990 mustang GT mustangcobra90 1979-1995 Mustang GT 12 06-25-2011 10:29 PM
08:45 AM
