Fox found - Page 2 - Mustang Evolution
Old 10-11-2011, 11:06 AM   #36
93slowstang's Avatar
If you want a good cheap upgrade get the maf housing off of an sn95 mustang and use your meter in it. Cost me 5 bucks from the junkyard and works great. You would have to buy an adapter to go from the housing to the intake as well.
Old 10-11-2011, 12:51 PM   #37
deadsp0t's Avatar
Question: aren't the 96-04 housings bigger then 94-95?
That's unimpressive
Old 10-11-2011, 01:02 PM   #38
Yes, mine is off of an 02 gt. Not sure but I think the v6 maf, housings are close to the same size as the 4.6 gt's.
Old 10-11-2011, 01:03 PM   #39
deadsp0t's Avatar
Cool, maybe an upgrade I'll look into. Ty.
That's unimpressive
Old 10-11-2011, 01:42 PM   #40
Jpstang's Avatar
Other than the housing and sensor, what else is needed to make the conversion.
Jpstang is offline   Reply With Quote
Old 10-11-2011, 02:37 PM   #41
This adapter, I got mine from a local speed shop.
Old 10-11-2011, 04:51 PM   #42
Jpstang's Avatar
Thx for all the help . I'm going to look into it. Does anything have to be done to the computer.
Old 10-11-2011, 05:54 PM   #43
deadsp0t's Avatar
Nope.
That's unimpressive
Old 10-11-2011, 06:17 PM   #44
Nope.
+1
Old 10-18-2011, 08:10 AM   #45
Jpstang's Avatar
Nope.
Would a maf sensor off a 91 mustang 4cyl work? Found a guy parting his car out. O guess all I would need is the sensor and the harnest from the sensor.
Old 10-18-2011, 10:03 AM   #46
Just realized something, what year is your car? It looks like it is a speed density system car.
---------- Post added at 11:03 AM ---------- Previous post was at 10:57 AM ----------
Didn't realize it's an 88. You need a maf sensor from a 90-93 5.0 mustang. I don't believe the 4cyl sensor will work. You also need a computer from the 90-93 5.0 car as well to convert to a maf system. You can use a 94-up mustang maf housing off of any model v6 or v8 as an upgrade as well.
Old 10-18-2011, 10:23 AM   #47
Jpstang's Avatar
Another newbee question, where's the computer on the car. I know another guy parting out a 90 5.0 but doesn't know anything about them.probably get a great deal
Old 10-18-2011, 10:24 AM   #48
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
There are a couple different maf wiring harnesses, make sure you grab the right one. Check your plug ins on the driversside(main harness plug/plugs) and also down by the computer. I've heard of people just getting the maf pigtail and wiring it into the harness and using a maf computer with no probs. Granetelli sells a pigtail kit for under $100 bucks which comes with instructions on how to install. I had it on my 87 gt for a while until I found a factory 89 maf harness that was a direct plug n play for 50 bucks. you can normally find meters all over but like others have said make sure you select the right one for your application.
EDIT: the computer is tucked between the car and the passenger side dash, remove the passenger kick panel and a 10mm socket and rachet to get the plug off the computer. Then you should be able to just pull the computer down and out. Can't remember if there's another small screw you need to take out to slide the comp out or not.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 10-18-2011, 11:28 AM   #49
Yes there is one the holds the computer in the bracket that has to come out before you can take the harness off.
Old 10-18-2011, 11:44 AM   #50
Jpstang's Avatar
Awesome thx guys
Old 10-18-2011, 11:49 AM   #51
Here is a link to help you out
http://www.musclemustangfastfords.co...n/viewall.html
got my first fox body!! 88foxstang 1979-1995 Mustang GT 18 09-16-2011 10:41 PM
best 4 eyed fox. 82stang224 1979-1995 Mustang GT 16 08-06-2011 09:08 PM
little problems in the fox. 82stang224 1979-1995 Mustang GT 10 07-29-2011 06:11 PM
Looking at trading the fox Qwik Four Six FYI Ads | Recently Listed 13 07-14-2011 11:36 AM
01:09 AM
