Boss 302 long block ? - Mustang Evolution
Old 10-08-2011, 06:56 PM   #1
BigRed1781's Avatar
I've done some searching on the forum & on the web & really haven't found an answer yet. I want to know if the stock or stock style efi would fit on the boss 302 create engine. I've been thinking of that engine with a tfs intake in my 95 gt. I want to keep the stock style efi & have the 4 bolt main ford block. I realize that there maybe others out there with 4 bolt mains but I really want to stick with a ford block. I'm sure someone here will be able to help me out with this minor dilemma of mine.
BigRed1781 is offline   Reply With Quote
Old 10-08-2011, 10:00 PM   #2
Re: Boss 302 long block ?
Yes, the Boss 302 block will work and it is less expensive than aftermarket blocks.
It uses the same components as the standard 302 block.
Old 10-08-2011, 10:25 PM   #3
93slowstang's Avatar
Trojan, hate to be the bearer of bad news but the boss block is more expensive than the aftermarket blocks. The boss short block is 4500 whereas most aftermarket long blocks are the same price.
Old 10-08-2011, 10:45 PM   #4
The Boss "Block" can be bought for around $1500-$1600. Dart and other aftermarket blocks start around $2000.
Boss Block
Dart Blocks
Boss "shortblocks" start around $4200 for a 331 CI and run up to $4400 for a 427 CI. The Dart shortblocks start at $4400 and go up to $6000 for a shortblock.
Boss Shortblocks
Dart Shortblocks
Depends on where you look I guess.
Old 10-08-2011, 10:45 PM   #5
deadsp0t's Avatar
Think I saw the short block(Boss) for $1700 in MM&FF in one of the bigger 2-page ads. I'll look later
That's unimpressive
Old 10-08-2011, 10:50 PM   #6
Boss Block
Dart Blocks
Boss Shortblocks
Dart Shortblocks
I was looking at the dss and chp blocks in comparison. Doesn't dart use the boss block?
---------- Post added at 11:50 PM ---------- Previous post was at 11:49 PM ----------
That's more than likely the bare block.
Old 10-08-2011, 11:04 PM   #7
6600 for a all alloy dart long block i think i saw on the net one day when i was surfing
Hawk is offline   Reply With Quote
Old 10-09-2011, 03:25 AM   #8
BigRed1781's Avatar
Awesome, thanks. I've been searching for ever trying to figure that out. Should have came here first. I want sure because the cooling passages on the boss block looks different than the standard 302 h.o block.
Old 10-09-2011, 04:31 AM   #9
No, Dart uses their own block.
Old 10-09-2011, 04:37 AM   #10
The Boss block has Siamesed cylinders, so the cooling passages will be different.
Note: The block is also set up for 1/2" head bolts, so most stock heads will not work without modification.
Old 10-09-2011, 05:06 AM   #11
BigRed1781's Avatar
Awesome thanks for all the info
Old 10-09-2011, 05:33 PM   #12
deadsp0t's Avatar
I believe you are correct sir
That's unimpressive
Old 10-09-2011, 06:30 PM   #13
BigRed1781's Avatar
So will heads for a 302 h.o. (like trick flow, edlebrock, ect) work on the boss block or are there specific heads designed to work on it?
---------- Post added at 08:30 PM ---------- Previous post was at 08:23 PM ----------
Never mind, I just answered my own question. I read the specs on the block. They do require specific heads. Wasn't the original boss a 302 windsor with cleveland heads?
Old 10-09-2011, 06:42 PM   #14
Yes, the original Boss 302 had the 351C 4V heads.
The Boss Block uses 1/2" head bolts, where the standard 302 uses 7/16" head bolts.
I believe most aftermarket heads that are drilled for 1/2" head bolts would probably work or could easily be made to work.
You would just have to check the heads/gaskets and make sure the water jacket holes lined up for proper cooling.
It is possible to put the 351C heads on a standard 302 block by drilling a coolant hole and using stepped head bolts, so I don't see why it would take much effort to use an aftermarket head with 1/2" bolt holes on a Boss Block.
It is what rodders do after all. They find ways to make things work.
Old 10-09-2011, 07:14 PM   #15
BigRed1781's Avatar
I have a question. What does the 4v stand for. I had a 351 4v in a f250. It didn't have 4 valves so I'm not sure what the 4v stands for.
Old 10-09-2011, 07:23 PM   #16
4 barrel carburetor.
It's a higher flow rate designation.
Old 10-09-2011, 07:26 PM   #17
BigRed1781's Avatar
Ah ha, 4 venturi. It's so obvious. Open mouth insert foot.
Old 10-09-2011, 08:25 PM   #18
Lol!
« Shifter | Irritated »
5.0 or Boss 302 The Darkside 2011-2014 Mustang GT 171 09-07-2011 09:48 AM
Boss 302 vs GT 5.0 poloka 2011-2014 Mustang GT 188 06-20-2011 04:08 PM
05:48 PM
