Will this work? - Mustang Evolution
Old 10-08-2011, 08:59 PM   #1
Qwik Four Six's Avatar
Will this work?
I know id have to buy some more pieces and stuff to get it to work with my carbed 5.0, like the hat for the carb, etc. So should I buy a new one or does powerdyne make hats for carbed cars? And I don't think this would make a difference, but would the blower work with a carbed car or just efi?
http://charlotte.craigslist.org/pts/2632522904.html
Qwik Four Six is offline   Reply With Quote
Old 10-08-2011, 09:12 PM   #2
BigRed1781's Avatar
Spectre makes a hat for carbs that allows you to use tubes like efi style intakes. I don't have any real experience with that type of sc on a carb but you may need a blow through carb.
BigRed1781 is offline   Reply With Quote
Old 10-08-2011, 09:19 PM   #3
Yeah. I will.
Old 10-08-2011, 09:23 PM   #4
93slowstang's Avatar
You can use a centrifugal supercharger but you need either a blow through carb with a hat, or a pressure box with a regular carb.
Hat
http://www.superchargersonline.com/p...er=SAT-4150R-P
Pressure box,
http://www.superchargersonline.com/p...=PAX8PM205-018
Old 10-08-2011, 09:23 PM   #5
BigRed1781's Avatar
http://www.jegs.com/i/Spectre/865/98...oductId=769283
Something like this might do the trick
Old 10-08-2011, 09:32 PM   #6
Should I keep my edelbrock 4 barrell 735 cfm carb? And what size fuel pump would I need to run 5-6 for a DD, and about 8 for racing?
Old 10-08-2011, 10:22 PM   #7
Re: Will this work?
If you use a "Hat" you will have to have a blow through carburetor.
The Edelbrock carbs are not one of my favorites, but it may be possible to modify it to work.
I would guess that you will need a fuel pump that will supply around 225 LPH at the pressures you specified.
You will be running lower fuel pressures, but you will need to supply sufficient fuel volume for your engine modifications.
Old 10-09-2011, 06:51 AM   #8
Alright thanks.
ABS light + traction control doesnt work RedGT04 1996-2004 Mustang GT 16 11-12-2015 06:43 PM
Left low beam headlight wont work but i will when i turn on high beams p1blake04 1996-2004 Mustang GT 4 09-05-2011 10:30 PM
Few cars I've worked on at work. Otlaw80 Pictures and Videos 8 09-02-2011 07:14 PM
Will a 6 cylinder C4 work with a 289 Tuch65 Classic Mustangs 2 08-11-2011 05:13 AM
Clutch work mcvicar04 1996-2004 Mustang GT 7 07-22-2011 07:59 AM
12:53 PM
