The box on the pass side engine compartment - Mustang Evolution
Old 10-09-2011, 01:49 PM   #1
Tj88mustang's Avatar
Is it a charcoal box? What does it do? And do I need it.
---------- Post added at 05:49 PM ---------- Previous post was at 05:48 PM ----------
I have a 88 hatch 5.0
Tj88mustang is offline   Reply With Quote
Old 10-09-2011, 03:06 PM   #2
93slowstang's Avatar
Mounted near the bottom then yes it's the charcoal canister. I believe it's required to pass emissions, but I left mine on in working order. No need to get rid of it.
Old 10-09-2011, 03:12 PM   #3
Thanks the guy who had this car before me decided to paint everything he could see under the hood either red or silver.. So I'm not trying to replace everything that's painted but if it is required I'll do it
Old 10-09-2011, 03:15 PM   #4
I just painted mine black, no need to bring attention to it.
Old 10-09-2011, 03:24 PM   #5
@93. Awesome ride, I have the 2" drop springs I haven't installed them yet hopefully within the next two weeks... Yours is the stance I'm shooting for. Looks great
Old 10-09-2011, 03:56 PM   #6
Thanks, the springs dropped it 2.25" overall. The ride quality suffered a lot but it handles like a dream. Don't forget caster camber plates when you lower it.
Old 10-09-2011, 04:06 PM   #7
Thanks I'm pretty sure it already has them right?
Old 10-09-2011, 05:21 PM   #8
That's factory, they won't adjust enough to fix your camber. Here's mine
Old 10-09-2011, 05:31 PM   #9
you have any suggestions of kinds
Old 10-09-2011, 05:58 PM   #10
deadsp0t's Avatar
Looks like there are spacers between the towers and plates? Mine have like base plates then plates on top of those that do the adjusting, I guess..?? Don't really kno a lot about them.
That's unimpressive
Old 10-09-2011, 06:04 PM   #11
Yea there's spacers, it also brings the shock up some more too. My tires have almost no negative camber now.
---------- Post added at 07:04 PM ---------- Previous post was at 07:02 PM ----------
I got maximum motorsports, they are probably the most recommended on this site. You probably can't go wrong with bbk or steeda but they are more expensive.
Old 10-09-2011, 06:20 PM   #12
Ok I'll look into getting them thanks for all the great info Much appreciated!!
Old 10-09-2011, 06:22 PM   #13
deadsp0t's Avatar
The alignment shop Couldn't get my alignment perfect, even with the plates. Is that normal? What might i do to correct that? Also I believe I need ball joints before too long as they pop sometimes.
Thinking about X2's.. Any thoughts?
---------- Post added at 08:22 PM ---------- Previous post was at 08:21 PM ----------
I have MM C/C plates too.
That's unimpressive
Old 10-09-2011, 06:52 PM   #14
Re: The box on the pass side engine compartment
Alignment shop is clueless then, go find another shop.
You can adjust for caster/camber and toe in/out with any aftermarket c/c plate. Unless your car is literally tucking tires it shouldn't be a problem. (i.e. Brent's old car)
Old 10-09-2011, 08:46 PM   #15
Np, I would go ahead and change shocks/struts when you lower it as well. Worn out shocks make a bumpy ride even bumpier.
---------- Post added at 09:46 PM ---------- Previous post was at 09:45 PM ----------
+1, I have to take mine in tomorrow after work and have it aligned. Been putting it off for a week do to the work schedule.
Old 10-10-2011, 09:27 AM   #16
I think I'll try to do that. Any suggestions?
Old 10-10-2011, 09:46 AM   #17
Adjustables would be the best way to go. I had koni adjustables on mine but put gabriels on due to my budget. Going to put adjustables back on when I get the money as they are kinda pricey.
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
02:31 AM
