starting problem - Mustang Evolution
Old 10-10-2011, 05:25 AM   #1
starting problem
have a starting problem changed starter and battery is good just clicks when trying to start
---------- Post added at 07:25 AM ---------- Previous post was at 07:20 AM ----------
is there any starting selonoid on firewall if so where is it located
chuck andres is offline   Reply With Quote
Old 10-10-2011, 06:47 AM   #2
Stang.racr's Avatar
Right next to the battery there is a starter solenoid. Like 10 bucks
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 10-10-2011, 07:29 AM   #3
Re: starting problem
I have been told there is no starting seloniod on my car except. On starter
Old 10-10-2011, 07:45 AM   #4
Stang.racr's Avatar
What kinda car do you have? They should be a object the size of a kids hand right beside your battery bolted down, it will have two studs coming out and wires bolted onto each with a single line slid onto the top post
Old 10-10-2011, 08:08 AM   #5
89 Foxloco's Avatar
Should look something like that!! Right next to your battery..
89 Foxloco is offline   Reply With Quote
Old 10-10-2011, 07:56 PM   #6
Region: Iowa
I wonder if thats what my deal is too.... Batt tests good, alternator seems to be strong (fires right up after BARELY push starting it) but if its on the trickle charger it starts up ?
Its an 88 gt. Stock alt, optima red top and no stereo wires or anything extra.
Bensfoxbody is offline   Reply With Quote
Old 10-10-2011, 07:59 PM   #7
Stang.racr's Avatar
So is it a starting or charging problem, leave it running and drop voltameter on battery post. You should get over 14 while running, if you didn't and alternator tested good then it's probably your fusible length
Old 10-10-2011, 08:04 PM   #8
Region: Iowa
I dont have a voltmeter but the gauge jumps right up to about 14 once it starts.
It was fine one day and then bam now this.
Old 10-10-2011, 08:09 PM   #9
Stang.racr's Avatar
I would check that solenoid out first. I have one more question though first, this starting problem, is it all the time or only after the vehicle has been running and shut off temporary
Old 10-10-2011, 08:28 PM   #10
Region: Iowa
Its when it sits for anything longer then about an hour. Like over night or while im at work....
Old 10-10-2011, 08:34 PM   #11
93slowstang's Avatar
I'm leaning more towards your battery. My car did that with an optima battery.
Old 10-10-2011, 10:12 PM   #12
Otlaw80's Avatar
you could have a power draw on the battery. Something that continues to draw power even when the car is off, causing your battery to drain enough that it won't start. Here is an article to read through and start your testing. Battery Drain Parasitic Draw Testing
Old 10-11-2011, 04:25 AM   #13
Do not have seloniod next to battery only seloniod is on starter.it is a 95 mustang gt 5.0
---------- Post added at 06:25 AM ---------- Previous post was at 06:20 AM ----------
There is no seloniod next to battery the only seloniod OS on starter. Oy is a 95 mustang gt 5.0
Old 10-11-2011, 07:24 AM   #14
Did you have the battery load tested?
Voltage testing will not give you an accurate indication of battery condition.
You could have one dead cell in the battery and it would still read 12 volts or more due to overcharging of the remaining cells. With that one cell out of commision you won't have the amperage it takes to start the engine.
I agree with 93slowstang in thinking the battery is shot because you say it starts with the charger on it.
« Tint | Cobra wheels »
95 5.0 starting problem stangrunner 1979-1995 Mustang GT 27 09-13-2011 08:48 PM
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 8 08-24-2011 09:51 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
Different Starting Problems milkrun49 2011-2014 Mustang GT 3 07-15-2011 02:19 PM
Shift knob problem with steeda tri-ax apex32 2011-2014 Mustang GT 5 06-29-2011 01:04 PM
02:19 PM
