Timing!! - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 10-11-2011, 11:58 AM   #1
89 Foxloco's Avatar
89 Foxloco is unknown around these parts
Timing!!
I have the 89 fox.. I got the timing gun.how do I advanceit.I looked up videos but non are specific.any help will be great thanks.
89 Foxloco is offline
Old 10-11-2011, 12:28 PM   #2
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
Ok by your distributor there is a plug with a grey connector in it. Pull it out, crank the car and loosen the dist clamp nut ( 1/2") and set your base timing.
---------- Post added at 01:28 PM ---------- Previous post was at 01:27 PM ----------
Here's an article that should help
http://www.muscularmustangs.com/timing.php
93slowstang is offline
Old 10-11-2011, 12:43 PM   #3
89 Foxloco's Avatar
Thanks...appreciated..
Old 10-11-2011, 12:45 PM   #4
stampde's Avatar
stampde is unknown around these parts
Re: Timing!!
screw the base timing , he wants it to run GOOD !!!!
Turn the dail on the advance light ( hoping you got that kind of gun )
to 14' degrees , then while she's running line the flashing light up with the timing marks by turning the distributor till the light lines up with the mark !!
old 5.0's run the best at 14' degrees advance !!! oh and use premium fuel afterwards
2006 Tungsten grey v6 Pony package
stampde is offline
Old 10-11-2011, 01:01 PM   #5
89 Foxloco's Avatar
So what do I do different and whats the difference from what 93slowstang told me??
Old 10-11-2011, 01:33 PM   #6
stampde's Avatar
Re: Timing!!
does your light have a dail on it ?
---------- Post added at 01:33 PM ---------- Previous post was at 01:23 PM ----------
if u have a dail ,set it to 14 then find zero on your balancer and mark it so u can see it .... and while running the zero should line up with the pointer with your gun at 14"
stampde is offline
Old 10-11-2011, 02:31 PM   #7
Moderator
For reference, if he set it to 20* that would make his BASE Timing 20*. But definitely advance it to 14*
---------- Post added at 03:31 PM ---------- Previous post was at 03:00 PM ----------
It would also help if you put white out on the 14* mark if you don't have a dial.
Old 10-11-2011, 08:04 PM   #8
Senior Member
Trojan Horse is just getting started.
Re: Timing!!
The article link that 93slowstang provided gives you all the information you need to set your "base" timing, whether you set it at 10 or 14 degrees.
Trojan Horse is offline
Closed Thread
« Motor Swap! | rims »
Timing advanced. 89 Foxloco 1979-1995 Mustang GT 1 09-25-2011 02:20 PM
99-04 GT Timing Chain tool? FORDGT14 1996-2004 Mustang GT 10 09-10-2011 02:06 PM
Need help with timing cover bolts WhiteCobra94 1979-1995 Mustang GT 33 08-11-2011 02:23 PM
advancing timing 5.slow 1979-1995 Mustang GT 6 08-10-2011 10:40 AM
timing gear drive peoblem? C4king 1979-1995 Mustang GT 8 08-09-2011 08:54 PM
» Members Mustangs
Jessi
miket89
Beemer
Konawin
Add your Camaro
10:52 PM
