95 8.8 5Lug Rear End into 87 5.0 Fox - Mustang Evolution
Old 10-12-2011, 12:44 PM   #1
Im currently doing major work to my car and have 5 lug spindles and complete w/brakes 8.8 track lok rear end and was wonder what kind of fit and finish im going to see with the rear end ive heard of offset issues and was wondering about parking brake cables as well any information you could provide will be greatly appreciated.
mcdonaldnick is offline   Reply With Quote
Old 10-12-2011, 03:02 PM   #2
It is doable but there is a few things to be aware of.switching from drum to disc brake.the parking brake may be different.and the axles maybe wider.I'm not exactly sure on specifics but someone else may chime in.in the mean time here is a similar thread.
Sn95 8.8 in my 85 GT
Old 10-12-2011, 06:03 PM   #3
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
I do know that the newer 8.8 will be a little wider than the factory 8.8 yours came with. You can always just get a different set if rims with the right offset to make it appear factory. Also I do believe you will need the newer brake booster as I've witnessed you have to literally stand on the brakes to get a fox to stop with rear discs. Adjustable proportioning valve is quite handy as well. I'm actually going to be doing a complete 5 lug swap from a 95 gt soon ad I get off my arse and go remove it all. You can get the factory e brake cables to work.....I just don't remember what needs done. EDIT: oh and if you are using the spindles from a 94-95 like iam, I was told you need to use the 94-95 ball joints since they are longer I believe. I've honestly been thinking about using the upper and lower arms off the 95 since I do believe it's the same k member buy don't quote me on that working ad I don't know for sure if the dimensions are the same between the fox and the SN.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Rear end swap bmabbott Pre-2005 V6 Mustang 9 10-01-2011 12:14 AM
Heavy vibration in rear end Blackedout Pre-2005 V6 Mustang 23 09-15-2011 02:35 PM
Rear end BigSteve305 Pre-2005 V6 Mustang 5 08-15-2011 09:25 AM
Rear end advice t0t4lbl4ck0ut 1996-2004 Mustang GT 6 08-07-2011 06:59 PM
Rear end in 1994 mustang V6 kevin Grove General Mustang Discussion 4 07-16-2011 06:14 PM
04:41 AM
