Money to blow - Mustang Evolution
Old 10-14-2011, 04:16 PM   #1
NateNasty's Avatar
Money to blow
Have around 200 bucks to blow on my stang what should I do?? It's pretty much stock.
NateNasty is offline   Reply With Quote
Old 10-14-2011, 06:20 PM   #2
jwhayne0001's Avatar
Cai or shifter
jwhayne0001 is offline   Reply With Quote
Old 10-14-2011, 06:30 PM   #3
deadsp0t's Avatar
Shifter, your tranny will live you
That's unimpressive
Old 10-14-2011, 06:32 PM   #4
Re: Money to blow
Shifter..
Old 10-14-2011, 06:47 PM   #5
It's not me, it's you.
primer2tone's Avatar
Anything, as long as it's not underglows.
Old 10-14-2011, 06:54 PM   #6
deadsp0t's Avatar
+1
That's unimpressive
Old 10-14-2011, 07:01 PM   #7
Kyle94GT302's Avatar
Well first what are your plans for the car? Performance and styling wise! Then start buying parts that will get you to your end result for the car. In the past I would always right up a parts list with pricing for what I wanted my car to preform and look like and start buying from that list a little at a time.
98 GT- Full PI swap, 93 tune, 3:73 gears,off-road h-pipe,flows, ported plenum and spacer, mac cai, lowered on eibach springs and eibach shocks and struts,spec stage 2 clutch, pro 5.0 shifter
94gt-H,C,I exhaust, eibach suspension--SOLD
Kyle94GT302 is offline   Reply With Quote
Old 10-14-2011, 08:46 PM   #8
NateNasty's Avatar
I have a hurst shifter actually lol. A cai or underdrive pullys
Old 10-14-2011, 08:52 PM   #9
I would go with the CAI, AM has some great prices for CAI's got there 80 dollar one on my 94gt and it looks great and performs the same as the name brand intakes it's just cheaper cause you are not paying for a name!! If you can find one cheap you can afford that and pulleys!!
Old 10-14-2011, 09:54 PM   #10
NateNasty's Avatar
Hell yes ebay!! How much hp would I gain with cai and pulleys?
Old 10-15-2011, 02:27 AM   #11
SleepingStang's Avatar
Subframe connectors. Yep it's not horsepower but it will stiffen the hell out of the car. Have them welded in. IMO cai's are worthless. You will be in the same boat with air silencer removed and a k&n installed.
SleepingStang is offline   Reply With Quote
Old 10-15-2011, 04:36 AM   #12
Sleeping has the right idea about suspension! Stiffing that pony up will greatly improve handling and reduce body roll. Springs, brace bars, subframe connectors and control arms will greatly revive the nimbleness of your stang!
Old 10-15-2011, 01:56 PM   #13
NateNasty's Avatar
I made my own cai and there's an automatic difference. You can tell it's not running as hard
Old 10-15-2011, 05:47 PM   #14
Howd you do that?
DrSalt22 is offline   Reply With Quote
Old 10-15-2011, 06:09 PM   #15
Vinnietbird's Avatar
Re: Money to blow
The factory air intake is already a CAI. Just remove the air silencer from the inner fender and install a quality filter. Gears are the best upgrade if you have someone to install them, or, find an '87/'88 Turbo Coupe rear. Disc breaks, either 3.55 or 3.73 gears,8.8 with traction Lock. Those can be had for $200 or less. You'll gain no power, but you'll think you did, and you'll feel the difference immediately.
1988 Thunderbird Sport...GT-40P engine, ported heads,Crane Gold 1.7 roller rockers, TFS-1 cam,Cobra intake,24# injectors,Mass Air, 8.8 with 3.55's, BBK headers, Pypes X-Pipe,40 series Flowmasters,3 row radiator,Taurus fan,17x9 and 17x10 10th ann. Cobra wheels,and more.....
Vinnietbird is offline   Reply With Quote
Old 10-15-2011, 06:37 PM   #16
If you somewhat mechanicaly inclined you can even install them yourself if have access to the right tools.
Old 10-15-2011, 08:42 PM   #17
Jpstang's Avatar
What kind of gears in a stock stang.
Jpstang is offline   Reply With Quote
Old 10-15-2011, 09:00 PM   #18
deadsp0t's Avatar
2.73, 3.08, or 3.27.
---------- Post added at 11:00 PM ---------- Previous post was at 10:51 PM ----------
About any really, more predominant in the newer cars though with 3.73, 3.55..
That's unimpressive
Old 10-15-2011, 09:24 PM   #19
Jpstang's Avatar
I think the 3.73 gears will be the first upgrade on my car.
Old 10-16-2011, 01:25 PM   #20
NateNasty's Avatar
Where is the best place to find 373s?? And I removed the thing with the ball in in, instead of just removing the ball then ran a new tube down through the fender with a filter on the end down on the end of the 28in pipe. Idk about y'all but I can tell a difference. Next I want gears!! If all I hear is true I should own with them.
Help me spend my money. aluppy General Mustang Discussion 10 09-23-2011 06:41 PM
1st car with own money. MichaelStai New Member Introductions & Greetings 8 08-06-2011 09:17 AM
wishing I had money right now. NeedSomeMods FYI Ads | Recently Listed 6 06-24-2011 09:06 AM
04:44 PM
