lowered or not - Mustang Evolution
Old 10-15-2011, 03:45 PM   #1
lowered or not
ok , so i finally put on my new tires on.i have also changed sway bar end links and shocks and struts. i went with kyb shocks and struts. i know they are nothing special or anything but they actually feel kinda stiff whitch is ok with me.i check my ball joints and tie rod when i changed the st/sh and they felt nice and solid.
the car feel kinda like it sways a little bit especially at higher speeds.
so my question is how to tell if its lower.it seems like it sit peetty low.if it was lowered previous owner never instaled c/c plates or bump steer.can i just count the loops on the spring or is there a better way to tell if its lowered.
appreciate any input.
Old 10-15-2011, 03:54 PM   #2
Here is a pic
Old 10-15-2011, 03:55 PM   #3
Also I had to buy a new jack a while back because my regular craftsman floor Jack wouldn't fit under it.
Old 10-15-2011, 05:19 PM   #4
93slowstang's Avatar
Based on the pic it looks like it has been lowered but not too much.
Old 10-15-2011, 06:03 PM   #5
Loc: Austin,TX
Re: lowered or not
Looks lowered to me also and if you are having problems getting a standard floor jack under it then thats a dead giveaway.
Old 10-15-2011, 06:05 PM   #6
can i just count the loops? or does lower springs have the same same amount of loops but different spacing in between them?if so how many loops does a stock spring have?btw thanx for the response.
Old 10-15-2011, 06:07 PM   #7
Don't know about counting loops, but maybe you can find a brand name or part number on them. Stock spring color is black also.
Old 10-15-2011, 06:10 PM   #8
Loc: Austin,TX
Re: lowered or not
What color are they?
Old 10-15-2011, 06:14 PM   #9
they are just black,but ththe whole area has been painted.i still believe they where black before the paint.also what are the symptoms of not having bumpsteer and c/c plates?
Old 10-15-2011, 06:19 PM   #10
How bad is your camber in the front? Your bumpsteer shouldn't be bad at all
Old 10-15-2011, 06:31 PM   #11
im not sure. how is the best way to check? camber is the wheels being paralell so to speak?
Old 10-15-2011, 06:47 PM   #12
Well straight up and down yes. You can have a shop check your alignment, maybe check the rest of your suspension as well.
Old 10-15-2011, 07:14 PM   #13
so if i did put c/c plates on, a shop will still have to do the alignment
right.so may as well just put them on first then take it in.for now i am saving money for a s/c. the wheather is telling me ill be parking it in the garage for the winter pretty soon anywas so i dont have to worry about messing my tires up or anything.hopefully i can score a good set of plates off ebay through the winter.
---------- Post added at 08:14 PM ---------- Previous post was at 08:13 PM ----------
thanx for the input.
Old 10-15-2011, 07:18 PM   #14
What I forgot to say was they may be able to align it without c/c plates if it's not bad.
Old 10-15-2011, 07:26 PM   #15
oh i got you.
it doesnt really pull hard in one direction or another.whats its doing is once i get going about 50 and up( it gets worse the faster i go), it kind of sway a little back and forth. almost a little bit like there is a small amount of play in the steering. i do have a almost brand new flaming river rack for it.i only bought that cause i didnt know if that was related to my issue, and i scored for 40$ at a swap meet.
Old 10-15-2011, 07:35 PM   #16
Re: lowered or not
Originally Posted by dreamstang View Post
oh i got you.
sounds like a good deal on the rack. Sounds like you need an alignment with it swaying like that. Mine didnt sway like that when i lowered it, and the camber was horible.
Old 10-15-2011, 07:38 PM   #17
cool cool. thanx man.
Old 10-15-2011, 07:41 PM   #18
Re: lowered or not
no problem
Old 10-16-2011, 06:43 AM   #19
deadsp0t's Avatar
Can't tell from the pics but how are the tires? Wear and pressure? Also the fronts, skinnies..? 4.5" or less??
That's unimpressive
Old 10-16-2011, 08:18 AM   #20
Brand new tires.I just started driving it recently so I couldn't really watch the wear.
Old 10-16-2011, 08:35 AM   #21
deadsp0t's Avatar
Also check the steering shaft. There is a u-joint with a bushing there. It may be becoming worn.
That's unimpressive
Old 10-16-2011, 08:36 AM   #22
Will do.thanx
Old 10-16-2011, 08:39 AM   #23
deadsp0t's Avatar
Just wondering.. Are you using P/S?
That's unimpressive
Old 10-16-2011, 09:09 AM   #24
Yes,brand new pump to.
Old 10-16-2011, 09:17 AM   #25
deadsp0t's Avatar
I asked cause the AC comp messed up on the wife's Mazda so I took the belt off. Now the steering feels funny/different.
Are the tires front and back the same width?
That's unimpressive
Old 10-16-2011, 09:59 AM   #26
Yes same width.
---------- Post added at 10:32 AM ---------- Previous post was at 10:30 AM ----------
I am running ac delete,smog delete,underdrive pulleys,New water pump, and new ps pump
---------- Post added at 10:34 AM ---------- Previous post was at 10:32 AM ----------
But I do believe the steering was that way before I messed with any of that
---------- Post added at 10:59 AM ---------- Previous post was at 10:34 AM ----------
ill check out the steering shaft joint but i think its probably gonna be alignment like slowstang said.thanx for the input!
Springs for Brembo 5.0 M3to5.0 2011-2014 Mustang GT 40 10-12-2011 05:31 AM
Lowered The Mustang robb15033 Pre-2005 V6 Mustang 25 09-21-2011 11:47 PM
Eibach lowered makes squeek IHBA 2011-2014 Mustang GT 3 08-04-2011 08:42 AM
Lowered My Mach LSUstang Pictures and Videos 13 06-25-2011 12:28 PM
» Members Mustangs
GIXX
Gixx
2014 Ford GT
Logiq
Add your Mustang
05:18 AM
