Et streets - Mustang Evolution
Old 10-16-2011, 12:56 PM   #1
04machazblue's Avatar
Et streets
Okay so I am thinking of picking up some et streets how would they be with stock axles and 410's
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 10-16-2011, 01:19 PM   #2
93slowstang's Avatar
With your current set up it should hold up fine.
Old 10-16-2011, 01:47 PM   #3
deadsp0t's Avatar
Agree, what size are thinking of?
That's unimpressive
Old 10-16-2011, 02:36 PM   #4
They are 255/50/16 for 280 with pony wheels
Old 10-16-2011, 04:37 PM   #5
Re: Et streets
You buying these just for the track?
If so why not buy some racestars and get a wider tire.
Old 10-16-2011, 05:49 PM   #6
Re: Et streets
Is this for your Mach 1 or a foxbody? You do know pony wheels are 4 lugs and will not fit a mach. If you're going to run these tires on your Mach you shouldn't have any problems, come with 31 splines from the factory.
If you are running these on a stock foxbody rear you are probably going to sling an axle with a good launch. Invest in a set of 31 spline explorer axles and c clip eliminator setup.
Old 10-16-2011, 05:52 PM   #7
deadsp0t's Avatar
The Mach is gone
That's unimpressive
Old 10-16-2011, 10:02 PM   #8
The Mach is gone
I got hit I'n the Mach and it's totaled and they came factory with 28 spline. I wanted to know if et streets would be okay with my stock axles
Old 10-16-2011, 11:23 PM   #9
And I am not launching at a high rpm I have a 3,000 stall I'n it
Old 10-17-2011, 12:59 PM   #10
deadsp0t's Avatar
Ya, I don't see it being an issue. Maybe someone else can chime in
That's unimpressive
Old 10-17-2011, 01:55 PM   #11
It's not like I am dumping the clutch at 5,000 rpm I am gonna be loaded at the at the line and there isn't going to be a sudden shock to the drivetrain Also wouldn't et street absorb a lot wrinkle and then take off
Old 10-17-2011, 03:31 PM   #12
Re: Et streets
As long as you pre-load the drivetrain before you dump the clutch completely and don't go wild with your launch rpm's you should be ok for a while. That's assuming that someone else hasn't already done those things to the car before. The slicks will cushion the initial blow, but eventually something has to give and either the car takes off or something breaks.
Eventually the factory axles are going to fail. They were never designed nor built to take that kind of abuse and would probably fail even if you never used slicks. Each time you launch the axles twist a bit and as you keep doing that they will not return to their original position more and more often until they finally snap.
Old 10-17-2011, 03:49 PM   #13
I can't drop the clutch anyways it's auto so yes premiering and Bo the car was never beat on I am the third owner the guy who had it before never took it to the track but had all the work done at a speed shop and a old lady owned it before him
Old 10-17-2011, 04:14 PM   #14
Re: Et streets
Then you should be good to go for quite some time. Enjoy.
Old 10-18-2011, 04:50 AM   #15
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: Et streets
If my old WS6, with the piddly-*** 7.5" 10-bolt can handle them, you should be fine. The stick awesome. I'm sure you will enjoy, just steer clear of the rain.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
$105 Track Day@ Streets of Willow Springs- Oct 29 in Socal Extremespeed Regional Mustang Discussion 1 10-25-2011 01:51 AM
$105 Track Day@ Streets of Willow Springs- Sept 24-25 in Socal Extremespeed Regional Mustang Discussion 2 09-17-2011 11:14 PM
12:36 AM
