starting slow - Mustang Evolution
Old 10-17-2011, 03:48 PM   #1
starting slow
Now that I have actually been driving my car it has a slow starting issue.I thought I had it fixxed .before I had a header leak that was pointed right at the starter.I fixxed that and it seemed to be fine.now that I've been driving it further distances the stupid demon is back.not as bad as it used to be.anyways I'm pretty sure its the ground wire.there is only 1 wire hooked up to the starter in the back.there is what looks to be a ground hooked to a bolt on the bell housing side but its not hooked up to anything else.so my question is can I just hook that wire to a chasis bolt.or should I run a nice new wire from the battery?thanx in advance
ID:	33167   Click image for larger version
ID:	33169   Click image for larger version
Old 10-17-2011, 03:52 PM   #2
Oh yeah,it starts great when its cold.
Old 10-17-2011, 04:21 PM   #3
Re: starting slow
You should have a battery ground directly to the engine and another to the body or frame from the engine.
The hard starting when it gets hot sounds like your starter windings are going bad or your exhaust is heating up the starter.
Old 10-17-2011, 05:02 PM   #4
I do have a both of those grounds. The battery to engine ground I even just recently replaced.I just wasn't sure if the starter needed its own.
That was my suspicion since it only does it when its hot.the problem improved after I fixxed my header leak but didn't fix.
It always still starts it just cranks slower when warm.
Thanx again TH
Old 10-17-2011, 06:01 PM   #5
Re: starting slow
Thanx again TH
You're Welcome
The slow cranking when warm means the windings are going.
The header leak probably damaged the winding's insulation and now whenever the starter heats up they are shorting out.
Do you have the newer model (94-95 I think) "mini" starter?
If not that's what I would replace it with.
Old 10-17-2011, 06:43 PM   #6
Originally Posted by Trojan Horse
You're Welcome
no i dont.i have the big one.i think its still the factory or factory replacement one.i definatly want to put the small one on.it will have more header clearance and be easier to install.that top bolt is a mother to get off the starter especially with shorty headers.my last round and it when i did the clutch the top bolt was stripped out and i had a heck of a time getting it off.i finally used a flexible die grinder attachment and was barely able to get it cut off.when i pulled the bell housing out i extracted it then.i almost thought about replacing it then.now i kick my self in the but.
Old 10-17-2011, 09:57 PM   #7
Re: starting slow
That's always the way. Hindsight is always 20/20 they say.
starting problem chuck andres 1979-1995 Mustang GT 13 10-11-2011 07:24 AM
Starting issues GunMetalBullet 2005-2010 Mustang GT 6 08-06-2011 10:24 PM
Different Starting Problems milkrun49 2011-2014 Mustang GT 3 07-15-2011 02:19 PM
Starting Issues bradh2414 Pre-2005 V6 Mustang 25 07-14-2011 08:43 PM
Starting my hunt for my next mustang! sonic04edge General Mustang Discussion 16 07-12-2011 07:03 PM
10:04 PM
