347 stroker - Mustang Evolution
Old 10-17-2011, 06:00 PM   #1
Stang89's Avatar
347 stroker
Is bore a stock 5.0 block 0.30 and stroking it 3.400 have to much stress on the block. Or would a 331 be less on the block. Has any one have any experience or know anyone with either setup. Also can I run gt-40 heads that are 64cc chambers. With 30 lb injectors and a bigger maf. I'm looking on getting 400 or close to that hp wise. Any ideas?
Stang89 is offline   Reply With Quote
Old 10-17-2011, 06:20 PM   #2
Re: 347 stroker
The 331 would be a better choice because it has a better rod/stroke ratio and doesn't scrub the piston walls quite as much.
My younger brother built a 331 and he's very happy with it. Not sure how much HP it makes as it has not been dynoed yet.
You can run the GT40 heads, but you will be much happier with the AFR 165's. There is an article (maybe in MM&FF Mag) where they added the AFR 165s to a mildly built 5.0 and gained 100 HP.
You may or may not need the 30 lb injectors depending on how much HP you develop. The bigger MAF would be a plus. Take a look at the ABACO MAFs. They can be tuned on your PC or laptop to work with almost any size injectors.
4.2L Stroker Blackheart4355 Pre-2005 V6 Mustang 24 10-12-2014 12:31 AM
Small block stroker book. Hawk 1979-1995 Mustang GT 12 09-13-2011 01:35 PM
427 stroker Hawk General Mustang Discussion 1 09-09-2011 08:18 PM
331 vs 347 82stang224 1979-1995 Mustang GT 10 08-01-2011 12:12 PM
How much does a 371 stroker kit cost? 94GTx306 1979-1995 Mustang GT 2 07-30-2011 09:25 PM
10:15 AM
