4 speed manny issues - Mustang Evolution
Old 10-18-2011, 07:10 PM   #1
351Stang's Avatar
So I bought a 83 and the roll pin broke that holds the reverse fork and shifter rod together.. Any tips on how to get to the shifter rod where I can push a new roll pin in?
351Stang is offline   Reply With Quote
Old 10-18-2011, 07:32 PM   #2
Re: 4 speed manny issues
Usually there is a top or side cover you can remove to access the internals.
Look up the numbers on the transmission and search online for a repair manual or exploded diagram.
You might want to consider just swapping it out for a newer 5-speed.
Over time you will likely save enough on fuel to make it pay for itself.
Old 10-19-2011, 07:31 AM   #3
351Stang's Avatar
Thanks, I'll just mess with it. If hate to buy a new trans just cause I can't get a pin in.
Old 10-19-2011, 01:35 PM   #4
Get the numbers off of your transmission so we can see what it is and we may be able to find you a diagram.
There should be a metal tag with the info on it.
Old 10-19-2011, 04:00 PM   #5
351Stang's Avatar
I found a bunch of exploded diagrams. I have come to another problem. The bushing directly st the bottom of the the shifter is damaged, any clue where to oder or get one? It's this "D" shaped bushing.
Old 10-19-2011, 10:47 PM   #6
Attachment 33279
Try one of our site sponsors - ME Vendors
Or maybe here - Toploader 4-Speed - if it is a toploader.
Old 10-20-2011, 09:50 PM   #7
94 Mustang GT's Avatar
Boy I hope you drive that car about 30k miles a yr to make up for the cost of a newer 5 spd! Haha.
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 10-20-2011, 10:25 PM   #8
Do you have a problem with something I said?
Old 10-22-2011, 08:43 AM   #9
351Stang's Avatar
I fixed it! Thanks
Old 10-22-2011, 10:25 AM   #10
I fixed it! Thanks
Glad to hear you got it taken care of.
Happy cruising.
Old 10-22-2011, 12:18 PM   #11
351Stang's Avatar
I appreciate the help
Speed demon? Evolution General Mustang Discussion 16 10-11-2011 10:23 PM
Misfire issues Ghostedmind Pre-2005 V6 Mustang 1 10-02-2011 12:52 AM
2011+ 5.0, lets have a poll on issues DDTCM 2011-2014 Mustang GT 36 09-14-2011 05:56 AM
Factory speed control or dealer speed control (cruise control) Otlaw80 1979-1995 Mustang GT 6 08-18-2011 07:42 PM
09:51 PM
