Hesatation problem/intake pop sometimes - Mustang Evolution
Old 10-18-2011, 09:17 PM   #1
04machazblue's Avatar
Okay so I was on my way home from work and I noticed my car was a little hesitating a little bit like a sputter sort of but after 2,200 rpms it's clears out and runs run and the popping happens every so often low rpm's timing checked out okay, plugs wires everything is I'n good shape. Could this be a vacuum leak?
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 10-18-2011, 11:08 PM   #2
Re: Hesatation problem/intake pop sometimes
Yes it could be, check your egr too and make sure it is working and the diaphragm does not have a hole in it.
Old 10-19-2011, 05:34 AM   #3
Okay well I noticed the line I'n the Pcv s cracked at the end that goes to the upper intake manifold I pulled the line and a lot of oil cam out like poured down my valve cover that's not normal
Is it
Old 10-19-2011, 01:31 PM   #4
Is it
No, it isn't normal for a lot of oil to be in there.
That could be a sign of bad rings or maybe the screen is missing from the PCV port in the lower manifold.
11:09 PM
