5.0 tuning help needed! - Mustang Evolution
Old 10-19-2011, 03:32 PM   #1
5.0Stangman's Avatar
Region: New Mexico
Im building a h/c/i combo for the stang. Trick Flow heads, ported Cobra intake, 70 mm BBK throttle body, and E cam. What do I need to maximize this combo? Is a Pro-m MAF and adjustable fuel-pressure regulator going to be good enough?
5.0Stangman is offline   Reply With Quote
Old 10-19-2011, 03:44 PM   #2
stampde's Avatar
Re: 5.0 tuning help needed!
I'd go at least 24lb injectors ,maybe 30's and make sure you get the meter calibrated for the injectors ( very important ) that's about all you need , old 5.0's are simple , you can get it tuned ,but on an old 5.0 it wont be worth the $$$ for a dyno tune ,they might be able to get you 5 - 10hp , you can pretty much get it dialed in pretty good ,with timing and fuel pressure !!! I'd say 38 psi and 14' initial timing
2011 GT Auto
Old 10-19-2011, 03:46 PM   #3
Region: New Mexico
The 24#'ers i had planned on. Thanks so much for the quick response!
Old 10-19-2011, 09:50 PM   #4
Region: New Mexico
I ordered heads and cam today my god I forgot how awesome stang fever was!
Old 10-20-2011, 01:10 AM   #5
Everything stampde said plus I would choose a Trickflow intake matched to your heads. They are designed to work together and should provide you with an increase in power.
Check out the ABACO MAF's. You can calibrate them yourself with your PC or laptop. No sending them in to be recalibrated if you change injectors.
Injectors not pulsing? Otlaw80 1979-1995 Mustang GT 21 07-27-2014 03:12 PM
Watch 5.0 Magazine test AmericanMuscle's 2011 V6! AMDanBailer 2011-2014 V6 Mustang 0 10-19-2011 12:47 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
What is the H O mean in a 5.0 crkmonzo 1979-1995 Mustang GT 16 08-30-2011 08:34 PM
Boss 302 vs GT 5.0 poloka 2011-2014 Mustang GT 188 06-20-2011 04:08 PM
09:21 AM
