Need help - Mustang Evolution
Old 10-20-2011, 07:00 AM   #1
Perplehawk's Avatar
Need help
I have a 94 gt and I was driving yesterday and noticed my oil pressure was alllllll the way on the l.....so I parked it and waited a hour and it was still high.... does anyone know what this means?
Perplehawk is offline   Reply With Quote
Old 10-20-2011, 07:15 AM   #2
Re: Need help
On the what?
If it is reading abnormally you either have engine/oil pump problems, or the gauge is malfunctioning.
Check your oil level.
Old 10-20-2011, 07:36 AM   #3
Perplehawk's Avatar
On the gauge it goes l normal h......and there is too much oil
Old 10-20-2011, 07:56 AM   #4
A.K.A. Baby-D!
Re: Need help
def. drain the excess oil.... but are you saying that your gauge is showing low oil pressure?
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 10-20-2011, 07:59 AM   #5
Perplehawk's Avatar
No its showing high
Old 10-20-2011, 08:10 AM   #6
A.K.A. Baby-D!
Re: Need help
drain excess oil and see what happens
Current:
Previous:
Old 10-20-2011, 08:51 AM   #7
mystang50's Avatar
Re: Need help
No its showing high
thats not good...drain it, check it...
could clogged up oild filter cause that??
Old 10-20-2011, 09:22 AM   #8
deadsp0t's Avatar
My first 95 was the same way, it was never like that until I changed to a 160 thermostat. The gauge in my current 95 goes to the N, but when you shut it off it swings almost straight down so I'm guessing it would be the same way and this car too appears ti have a 160 thermostat.
See how low it is at rest? Should be like the volt meter above at rest. Also note there is no red block on the high side of the oil pressure gauge.
That's unimpressive
Old 10-20-2011, 11:02 AM   #9
Re: Need help
Too much oil is an indication of a blown head, intake or coolant gasket.
Or possibly a fuel pressure regulator has blown the diaphram gasket.
Your crankcase is likely full of:
A- Coolant mixed with oil. (Oil will be a brown, milky color.)
B- Gasoline mixed with oil. (Oil will smell like gasoline and it will catch fire easily.)
DO NOT run the engine again until the cause is found, fixed and the oil and filter have been changed.
Old 10-20-2011, 01:17 PM   #10
Perplehawk's Avatar
The thermostat sits normal at rest.... And the oil is not milky......
---------- Post added at 01:17 PM ---------- Previous post was at 01:16 PM ----------
I just got an oil change and now have the correct about of oil and still does the same
Old 10-20-2011, 01:21 PM   #11
Otlaw80's Avatar
Possibly a gauge malfunction. Try a new oil sending unit. But I would Def be more worried about why there was to much oil. Did u just get car?
Old 10-20-2011, 01:39 PM   #12
Stang89's Avatar
Yeah I would be worried if you just got the car. If there was a lot of
Oil in the pan like that then there is something wrong that the buyer is hiding from you that may be a serious problem in the future. But if everything checks out ok with no noises or knocking you might be ok. I would look into a sending unit as they say above. It could be something stupid. Keep us updated.
Stang89 is offline   Reply With Quote
Old 10-20-2011, 03:39 PM   #13
Re: Need help
Then the pressure bypass spring/valve in the oil pump must be stuck if the gauge is ok.
Did you check the oil for gasoline?
Any other idea as to why it was overfilled?
Old 10-20-2011, 04:03 PM   #14
Filibuster
Im goin through a similar problem with my camaro,and I suspect a fuel pressure regulator as TH stated!...the oil will be thin and deffinatly smell of gass!..i would look into this as best you can before any serious damage!...good luck!
XXSTEVEO66 is offline   Reply With Quote
Old 10-22-2011, 06:18 AM   #15
mystang50's Avatar
Re: Need help
can u ground it like temp sending unit?, if u can do that to check gauge...
11:56 PM
