new mustang more problems - Mustang Evolution
Old 10-20-2011, 09:41 AM   #1
04machazblue's Avatar
okay so i jst got this foxbody like a week ago and already its running like crap. i looked up and down had a couple friends look at it who build mustang and we found nothing checked for vacum leaks sensors, but i smelled a little wire burn the car has a chip and was tuned, is it possible that the chipped burned up and its running like crap bc of it
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 10-20-2011, 09:49 AM   #2
Fox5.0's Avatar
Whats done to it to need a chip/tune? I'd take the chip out see if it runs better? What's it doing to make u feel like it runs like ****?
Fox5.0 is offline   Reply With Quote
Old 10-20-2011, 09:57 AM   #3
93slowstang's Avatar
Could have done like mine and fried the ECM, worst case scenario of course.
Old 10-20-2011, 10:21 AM   #4
Re: new mustang more problems
all the mods are in my signiture and it was in the car when i got it
---------- Post added at 12:21 PM ---------- Previous post was at 12:20 PM ----------
if i did fry the ecm how much do they run
Old 10-20-2011, 10:45 AM   #5
I had mine rebuilt. Normally runs about 80-130 depending on which store you go to but they all go to the same place. Never priced a new one. It's not likely you did fry it but it's easy to check.
Old 10-20-2011, 11:37 AM   #6
it runs like crap till almost 3 grand then it clears up
Old 10-21-2011, 06:00 PM   #7
Don't worry it seems to be a mustang thing which is really making me want to sell .
tbonestang is offline   Reply With Quote
Old 10-21-2011, 09:40 PM   #8
well the problem was the carwas tuned and had a chip in it and it failed took it out runs fun but surges i think the alternator is on its was out checked the IAC and the TPS the sensor has the right volts going to it. but i noticed the voltmeter drops sometimes and goes back up back and fourth
Old 10-24-2011, 09:29 AM   #9
Titus Wadicus
svtlx's Avatar
wuts the fuel pressure set at? 30lbs injectors may be large for that set-up (possibly why it had to be tuned). i think 24lbs injectors may be better.
just my two cents. i would start with the fuel pressure first.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 10-24-2011, 09:49 AM   #10
Brett Greene's Avatar
Remember your driving a Fox. These are creak, groan and make weird
Noises all the time. **** normally buffs out
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 10-24-2011, 11:18 AM   #11
Have you checked your ignition system, timing, plugs, wires, cap, rotary, etc.?
Old 10-25-2011, 06:48 AM   #12
Question Re: new mustang more problems
Well thTs the first thing I checked the cap and rotor looked a little beat changed that and all other ignition parts are fine. I am almost positive it's the alternator I have a 190 fuel pump after market radio that's draws some power and power windows and and the alternator is prolly 10 years old and I have mug cell phone plugged in charging I guess it's time to upgrade to 3G
Old 10-25-2011, 09:38 AM   #13
Titus Wadicus
svtlx's Avatar
30 second wit my grinder and 15buks at the junkyard and I upgraded to a 3g. U definatley need to upgrade, but I think ur surging is n tuning, not voltage. But da alternator would b a great place to start suppose.
Old 10-25-2011, 10:04 AM   #14
stampde's Avatar
Take off the IAC and CLEAN it out Joe ... just sayin'
2011 GT Auto
Old 10-25-2011, 01:18 PM   #15
NateNasty's Avatar
+1
NateNasty is offline   Reply With Quote
Old 10-25-2011, 06:22 PM   #16
Tj88mustang's Avatar
I feel like a moron ....IAC?
Tj88mustang is offline   Reply With Quote
Old 10-25-2011, 06:28 PM   #17
MC770's Avatar
Idle Air Control
I believe is what it means
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 10-25-2011, 07:02 PM   #18
Lol thanks
Old 10-26-2011, 06:26 AM   #19
It Has a new I Ac on there guys it has gotten a lot better but still has
A problem
Old 10-26-2011, 08:56 AM   #20
NateNasty's Avatar
Isn't that fun? That happened to me I was pissed. In my case I had a large vacuum leak at my firewall and my idol was off along with my maf sensor, that had to be tuned. Your making progress!
« seats... | maf »
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
02:02 PM
