Bellhousing block mounts - Mustang Evolution
Old 10-20-2011, 12:57 PM   #1
Cm644rodrigues's Avatar
It a 302 block bored.040 just too it down to block and noticed that the bellhousing bolt hole furthest on passenger side is cracked. Is the block garbage? I think it happened during transportation. It now bolted to the engine stand. Cab I keep it and rebuild the rest of the block is mint
Cm644rodrigues is offline   Reply With Quote
Old 10-20-2011, 01:02 PM   #2
Re: Bellhousing block mounts
.040 is .010 over the largest recommended over bore of .030 for a factory 5.0 block.
It should be ok for a stock rebuild, but I wouldn't use it in a performance application.
Old 10-20-2011, 02:02 PM   #3
Otlaw80's Avatar
As Trojan said. If your going with stockish build you'll be fine. I've run a mustang for a couple years with one bolt missing for the same reason.
Boss 302 long block ? BigRed1781 1979-1995 Mustang GT 17 10-09-2011 08:25 PM
Small block stroker book. Hawk 1979-1995 Mustang GT 12 09-13-2011 01:35 PM
GT500 strut mounts gtstyles2 2011-2014 Mustang GT 3 09-02-2011 03:08 PM
01 block Mustanglife General Mustang Discussion 15 07-26-2011 08:27 PM
01:35 PM
