Easy way to change fuel pump lol - Mustang Evolution
Old 10-21-2011, 04:17 PM   #1
As u man no I am puttin a turbo on my 89 gt the bolts that hold the gas tank up were completely stripped and rounded so I cut the floor out with tin snips and changed it from inside the car...worked perfect lol
Z06 eater is offline   Reply With Quote
Old 10-21-2011, 07:52 PM   #2
Re: Easy way to change fuel pump lol
Great idea!
When I get back to work on mine I plan to cut out the area above the fuel pump and make a hinged "door" to enable easy access to the fuel pump.
That's definitely MUCH easier than draining and removing the fuel tank.
Old 10-21-2011, 08:01 PM   #3
Yes it was so easy and I also cut out to put a new gauge in the tank
Old 10-21-2011, 08:57 PM   #4
I may also use this trick.not for sure yet,but I will def. Look into it.a lot of people do this in many vehicles.
Old 10-21-2011, 10:25 PM   #5
93slowstang's Avatar
Mine may get done now, never thought about doing that before.
Old 10-22-2011, 06:20 AM   #6
back n a stang's Avatar
Alot do nice clean professional cut and works great.
injectors and fuel pump CancerBoi69 Pre-2005 V6 Mustang 1 10-14-2011 07:28 AM
Fuel pump? 96 stang 1996-2004 Mustang GT 10 09-21-2011 10:07 PM
Bad Fuel Pump?? jal4411 1979-1995 Mustang GT 7 09-17-2011 02:32 PM
Fuel pump constantly running Albaraptor 1979-1995 Mustang GT 3 08-28-2011 02:55 PM
11:00 PM
