Headlight adjustment - Mustang Evolution
Old 10-24-2011, 10:56 AM   #1
jhagan1980's Avatar
Not sure how to adjust, I'm needing to raise one up but not sure what to turn. Pics would be very helpful, my Haynes book does not explain well at all. Thanks
jhagan1980 is offline   Reply With Quote
Old 10-24-2011, 11:13 AM   #2
Re: Headlight adjustment
See the picture below.
Name:	94-95 Mustang Headlight adjust.jpg
Old 10-25-2011, 06:46 AM   #3
jwhayne0001's Avatar
I can get the special 4mm long wrench from work to aim the lights i did mine
jwhayne0001 is offline   Reply With Quote
Old 11-07-2011, 08:32 PM   #4
How did you use a wrench to do it? As shown in the picture above, the adjustment screw has a Philips head on it.
I just replaced my headlights, and as far as I can see, this is the only way to adjust the vertical alignment.
You'd think this was some kind of national secret; in 40 minutes of searching, this is the first picture I've seen that even attempts to show the adjustment for a Mustang. Every other site and article just half-assedly refers to "the adjustment screw", or describes where it might be (but, on the Mustang, isn't).
Stokestack is offline   Reply With Quote
Old 11-08-2011, 05:26 AM   #5
I just replaced my headlights, and as far as I can see, this is the only way to adjust the vertical alignment. And it requires removing the side marker lights to expose the screw.
Behind the headlight directly behind the Phillips is a 4mm hex head
---------- Post added at 06:26 AM ---------- Previous post was at 06:23 AM ----------
http://www.latemodelrestoration.com/...justing-Wrench
Old 11-08-2011, 10:46 AM   #6
Interesting. I'll have to take a look at my old assembly.
I'm pretty sure the screw is the intended adjustment, though. It turns out that you can insert a thin screwdriver between the side marker light and the headlight and adjust the aim without even opening the hood.
Old 11-08-2011, 11:22 AM   #7
Now that I look at mine that's what it seems to do, I was just goin by my dealership that I work at, the workshop manual
Old 11-08-2011, 02:21 PM   #8
The lack of clear, reliable info on this simple task is just baffling! I took a bunch of pictures of the process of replacing my lights, so I made a gallery. Take a look at my pictures for the process:
http://www.mustangevolution.com/foru...508-albums1687
Old 11-08-2011, 03:44 PM   #9
Mustang Evolution - Stokestack's Album: headlight replacement
Nice job!
When I feel a bit better I'll put those in a, How to PDF file for you that you can share with others.
Old 11-08-2011, 03:48 PM   #10
Cool, thanks. No need to do that for my sake, though; I have Acrobat, and I'll probably also create a Flickr set for general sharing.
Need Advice. Mustang Headlight Fogged Up. AllanBane 1996-2004 Mustang GT 3 10-17-2011 06:37 PM
headlight restoration best product? dbroncolish 1996-2004 Mustang GT 8 09-19-2011 04:09 PM
Left low beam headlight wont work but i will when i turn on high beams p1blake04 1996-2004 Mustang GT 4 09-05-2011 10:30 PM
Mothers all in one headlight restoring kit znpzmustang Mustang Paint, Appearance & Detailing 9 08-09-2011 06:11 PM
Headlight Aaron vassallo 1996-2004 Mustang GT 2 07-01-2011 07:10 AM
02:05 AM
