Revs staying up. - Mustang Evolution
Old 10-25-2011, 09:04 AM   #1
Chefnick's Avatar
Revs staying up.
If I rev up my car the rpms only come down to about 1500 to 2000 rpms. Stays there for Bot 7 to 10 seconds and then drops down to idle. Does anyone know why this is?
Chefnick is offline   Reply With Quote
Old 10-25-2011, 09:55 AM   #2
back n a stang's Avatar
Re: Revs staying up.
Clean throttle body maybe...
Old 10-25-2011, 10:19 AM   #3
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Check your throttle cable spring, might be sticking a little bit, also could be a tps issue but normally that also causes rough idle with the rpms surging up and down at idle. Could also try cleaning your idle air control valve to see if that helps any.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 10-25-2011, 10:44 AM   #4
Chefnick's Avatar
Sting is good. It opens and closes fine. Dident take off throttle body but lookenin it and it does not dirty or gunked up
---------- Post added at 10:44 AM ---------- Previous post was at 10:43 AM ----------
And when I first start it the rpms go way up and down for a bit
Old 10-25-2011, 12:09 PM   #5
Pete Jones
Could be a faulty tps sensor, what year in the car?
90 LX hatchback
89 LX Notchback
Old 10-25-2011, 01:17 PM   #6
NateNasty's Avatar
Your computer is confused. Mine did that, mine was the idol after checking everything. Maybe clean your iac toooo.
NateNasty is offline   Reply With Quote
Old 10-25-2011, 01:47 PM   #7
Fox5.0's Avatar
Iac sounds like to me
Fox5.0 is offline   Reply With Quote
Old 10-25-2011, 08:41 PM   #8
Chefnick's Avatar
Going to check iac tomorrow and maybe see about getting a new tps Car is a 93
Old 10-25-2011, 08:41 PM   #9
Usually it is a bad TPS or your 10-Pin connector is not making good connection.
See this post for a link to more information.
Useful Mustang Information
Old 10-26-2011, 03:37 PM   #10
Chefnick's Avatar
And the winner is....... Bad tps. Put a new one one for $35 and it fixed the prob
Old 10-26-2011, 04:41 PM   #11
Glad you got it fixed.
Old 10-26-2011, 07:06 PM   #12
5oh
5oh's Avatar
Idle control sensor sounds like its bad, try carb or throttle cleaner, take it off the throttle body and spray it inside, if not get a motor craft one from the dealer or 50 resto online it's about $100-120. If you get and idle surge constantly it's your mass air flow sensor.
---------- Post added at 08:06 PM ---------- Previous post was at 08:01 PM ----------
Disregard what I said! Tps that's new to me, didn't know that would keep you revs up, I guess having the wrong voltage will cause that.
5oh is offline   Reply With Quote
Car not staying charged Jettin Stang 1979-1995 Mustang GT 16 08-17-2011 10:12 PM
Max revs? 11stangGT 2011-2014 Mustang GT 30 07-16-2011 07:11 PM
09:56 PM
