Clutch - Mustang Evolution
Old 10-25-2011, 03:33 PM   #1
jhagan1980's Avatar
Clutch
Is this a stock clutch? I'm guessing it is.
jhagan1980 is offline   Reply With Quote
Old 10-25-2011, 04:32 PM   #2
jhagan1980's Avatar
It says Ford M7563-C302N
Old 10-25-2011, 04:45 PM   #3
I believe its a king cobra clutch.I did some googling and its definatly Ford racing.
Old 10-25-2011, 04:59 PM   #4
jhagan1980's Avatar
King cobra says ford on it?
Old 10-25-2011, 05:08 PM   #5
I think Ford racing makes king cobra.that's the clutch I have but I don't remember exactly.
Old 10-25-2011, 05:50 PM   #6
93slowstang's Avatar
Yep that's a king cobra clutch, and yes ford racing makes it.
Old 10-25-2011, 06:05 PM   #7
jhagan1980's Avatar
Well cool. Hopefully after I inspect it it'll still be in good shape and I'll just have to replace the throw out bearing.
Old 10-25-2011, 08:24 PM   #8
Re: Clutch
Yes it is a KC.
King Cobra Clutch
Old 10-25-2011, 08:45 PM   #9
jhagan1980's Avatar
I guess when I take it apart I'll find out if it's a matching clutch disk. How can I tell if it's still a good clutch? I'd like to just replace the TOB and the clutch fork but I'll replace the clutch if I need to.
Old 10-25-2011, 08:49 PM   #10
Re: Clutch
Check the surface and make sure it isn't worn down to the rivets that hold the disk material on and that none of the material has cracked or broken off.
Also check your flywheel for evidence of heat discoloration or chatter marks.
Old 10-26-2011, 08:58 AM   #11
jhagan1980's Avatar
The flywheel is smooth to the touch but looks to have blue spots. Will resurfacing correct this? The only chips I could find on the disc is the ones in the pics. The pressure plate has blue spots as well. If it needs to be replaced so be it. Looking for opinions.
Old 10-26-2011, 04:31 PM   #12
Re: Clutch
Yes, resurfacing will remove the marks and give you a flat fresh surface to start with.
The flywheel looks like it needs to be resurfaced.
It looks grooved around the circumference?
The clutch disk itself looks ok. The small chips around the edges are normal and will not hurt anything.
The pressure plate looks pretty good.
If you have a D/A Sander and some 60-80 grit paper for it, it wouldn't hurt to sand it down a bit to remove any minute chatter marks or waves in the surface of the pressure plate contact disk.
Just get the D/A started and keep it moving around the disk, don't stay in one place.
Old 10-27-2011, 09:55 AM   #13
jhagan1980's Avatar
Is there anyway to tell if that's the rear main seal or the oil pan? I'm gonna change the RMS anyway but if it's the pan I'm gonna tackle that as well seeing how I have the tranny out.
Old 10-27-2011, 10:04 AM   #14
Brett Greene's Avatar
Upgrade to a light weight fly wheel of you have the cash. My aswell if you have very thing apart
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 10-27-2011, 11:25 AM   #15
Re: Clutch
Attachment 33610
It's kind of hard to tell, but I would suspect the main seal first.
If you do the pan gasket, you will have to unbolt the motor mounts, lift and support the engine to get the pan off. Be sure you replace the pan gasket with a one-piece gasket if you do it.
Old 10-27-2011, 11:27 AM   #16
Re: Clutch
I wouldn't do a lightweight or aluminum flywheel unless you are into road racing. There are no good benefits to be had using them on a drag or street car.
Old 10-27-2011, 11:34 AM   #17
jhagan1980's Avatar
I'm just gonna order the kit with king cobra clutch and the stock flywheel.
Clutch eouellette18 2005-2010 Mustang GT 9 09-08-2011 03:51 PM
Clutch just went 04machazblue 1996-2004 Mustang GT 9 08-24-2011 05:41 AM
Spec or ram clutch 04machazblue 1996-2004 Mustang GT 3 08-23-2011 04:36 PM
Need advise on a new clutch j4gwig General Mustang Discussion 1 08-01-2011 07:51 PM
Clutch? :( nickysixx 1996-2004 Mustang GT 5 07-08-2011 04:13 PM
03:26 AM
