cobra intake.. - Mustang Evolution
Old 10-25-2011, 03:46 PM   #1
mike hawk's Avatar
cobra intake..
Wat would be a good way to get my intake cleaned up..
mike hawk is offline   Reply With Quote
Old 10-25-2011, 08:30 PM   #2
Re: cobra intake..
Remove it, wash it, bead blast it, repaint it.
Or carefully wash it on the car with soap and water.
Just don't use a high pressure hose, because you might force water into electrical connectors or other areas it should not be in.
Old 10-25-2011, 08:52 PM   #3
mike hawk's Avatar
I bought it used not that long ago and still havent installed it yet so I just want to clean the inside...
Old 10-25-2011, 09:15 PM   #4
Re: cobra intake..
Then just take some carb cleaner and wash it out.
Old 10-27-2011, 09:12 PM   #5
TrickFlow94's Avatar
Pressure washer and simple green works pretty good!
TrickFlow94 is offline   Reply With Quote
Old 10-28-2011, 06:58 AM   #6
Simple green is the bomb I bring a gallon home from work n my lunch pale about once a month lol
Z06 eater is offline   Reply With Quote
Old 10-28-2011, 07:27 AM   #7
Re: cobra intake..
yea you can remove it, have it striped and re-coated if you cant get it cleaned any other way or you could hand polish it (takes forever) then clear coat it etc~ or have some other coating done to it (they have all sorts now)
Old 10-28-2011, 10:13 AM   #8
Re: cobra intake..
NOTE:
If you ever get a chance to try some, check out the Morado purple soap from ZEP Manufacturing. Zep Morado Super Cleaner
It makes Simple Green look like hand soap.
It will actually etch/dissolve aluminum at higher concentrations and remove or etch paint. We have actually used it to pre-clean painted surfaces in prep for repainting. It does a great job of removing any oils or greases and etching the paint. You just have to be careful and not leave it on to long.
Also DO NOT get it on your skin. It burns and will turn the skin on your hands to a rubbery consistency, then a day or two later the outer layers of your skin will peel off. So use it with good common sense and caution and pay attention to the instructions on the label.
Need help 03 cobra Jamesgt08 1996-2004 Mustang GT 27 09-16-2011 06:39 PM
Cobra Pricing Opinions... 2008Shelby SVT Mustang 25 09-04-2011 03:49 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
Trade for cobra??? 93stang306 1979-1995 Mustang GT 26 07-01-2011 10:13 PM
01:31 AM
