idle problems - Mustang Evolution
Old 10-25-2011, 09:06 PM   #1
brian94gt's Avatar
idle problems
My stang has a rough and fluctuating idle. It also likes to stall out occasionally when at idle. It also has somewhat of a studder at very low rpms. I can also smell that it is running rich any suggestions
brian94gt is offline   Reply With Quote
Old 10-25-2011, 09:19 PM   #2
Re: idle problems
Make sure your MAF is matched to the injector size you are running.
Clean the MAF and IAC.
Check for vacuum leaks.
Clean and check the EGR to make sure it is operating correctly.
Old 10-25-2011, 10:06 PM   #3
brian94gt's Avatar
The entire car is stock but what is a egr and a iac
Old 10-25-2011, 10:17 PM   #4
Re: idle problems
EGR = Exhaust Gas Recirculator Valve
IAC = Idle Air Control
Old 10-25-2011, 10:25 PM   #5
brian94gt's Avatar
Oh ok thanks man I I read on a couple of other forums that other ppl were experiencing the same symptoms due to a leaking intake manifold gasket do u think that could be a possibility aswell
Old 10-25-2011, 10:36 PM   #6
jhagan1980's Avatar
Not saying it couldn't be but it's alot of work to pull the intake and check. The maf, erg, and iac are easier to get too and check.
jhagan1980 is offline   Reply With Quote
Old 10-26-2011, 04:39 AM   #7
brian94gt's Avatar
Oh ok well ill try those probably today and ill let u know how it goes I appreciate the advice
Old 11-20-2011, 03:11 PM   #8
brian94gt's Avatar
Sorry u haven't updated this post in a long time but I cleaned my maf and my iac but the problem is still occurring I've noticed that the stalling at idle once the car is warm has is becoming more frequent and now every once in a while at idle the check engine light will flash and the idle will shoot up to around 2000rpm I have also replaced the oscar gasket
Old 11-20-2011, 03:22 PM   #9
So have u checked your codes yet?
Robbie94gt is offline   Reply With Quote
Old 11-20-2011, 03:23 PM   #10
Re: idle problems
What's an "oscar" gasket?
Old 11-20-2011, 03:33 PM   #11
Re: idle problems
mine did the same thing it was the ac vacume line came unhooked from fire wall that was the whole prob
kid_kash_00 is offline   Reply With Quote
Old 11-20-2011, 04:32 PM   #12
brian94gt's Avatar
Sorry my auto type on my phone sucks but I meant to say iac but I tried to hook it up to a scanner at autozone and it kept saying error connecting to ecu
Old 11-20-2011, 05:39 PM   #13
Ok I guess u tried hooking it up to the one under the dash. That is a obd2 connector. Amd it is not hooked up. That connector is for 96 amd up cars. U need to hook up to the one thst is under the hood on the passenger side. U might be able to get autozone to do it but I doubt it. They usually will only do it on the obd2 cars 96 amd up. Your car is obd1 computer system
Old 11-20-2011, 06:48 PM   #14
brian94gt's Avatar
Oh really ok that's good to know I guess I need to take it to a shop then
Old 11-20-2011, 06:59 PM   #15
jhagan1980's Avatar
http://dfwmustangs.net/forums/showthread.php?t=7908
This will show you how to read the codes yourself.
Old 11-20-2011, 11:06 PM   #16
brian94gt's Avatar
Heck yeah thanks ill have to try it tomorrow
Old 11-20-2011, 11:50 PM   #17
Ruthless's Avatar
Take a can of starting fluid and spray it around your intake. That's the best way to check for vacuum leaks. The engine will rev up if starting fluid is sucked into the system. If the problem is getting worse then it would make sense to me that it could be a gasket perhaps your intake. Which is essentially a huge vacuum leak. And +1 on the obd1 and 2 info. Good info.
Ruthless is offline   Reply With Quote
Old 11-21-2011, 03:28 AM   #18
Furious35's Avatar
Region: Arkansas
Just to jump in here. 94-95 V6 stangs are OBD2 that's why we have the plug under dash but the gts were still OBD1s. Yes you can check them yourself by jumping the self test pin and the VIP pin plug under your hood. Just count the flashes. Sounds like a vacume leak to me. Our sn95s are bad about that I haven't found a deffinite reason yet. Lol. Maybe O2s since it only does it warmed up. Those are the two main sensors our cars use and the ecu dosnt use them till 170 degrees I belive. Also clean your throttle body good and MAF. ONLY USE BRAKE PARTS CLEANER OR ELECTRICAL CLEANER on your MAF because it dosnt leave reasadue hope this helps
Furious35 is offline   Reply With Quote
Old 11-21-2011, 04:52 AM   #19
jhagan1980's Avatar
Mine is a cobra and I have the port under my dash too, it's just useless. They make a MAF cleaner I would buy before I used brake or electrical cleaner.
Old 11-21-2011, 05:55 AM   #20
U can look on here to how to do a base idle reset. That's what I did after I cleaned my iac and tb. It's helped dramaticly.
Old 11-21-2011, 06:07 PM   #21
Break cleaner or electrical cleaner is fine.they both dry fast and leave no residue.that's all that matters.residue will cause inaccurate readings.
Old 11-21-2011, 09:37 PM   #22
brian94gt's Avatar
Thanks everyone I still haunt had time try this stuff my schedule is pretty tight right now but as soon as I have time im definitely gonna try to track down the problem(s) but were can I find how to do an idle reset
Old 11-21-2011, 09:44 PM   #23
93slowstang's Avatar
Check the stickies, the instructions are there.
humming noise during idle robertoortiz85 1996-2004 Mustang GT 6 10-23-2011 03:12 AM
Stupid idle NateNasty 1979-1995 Mustang GT 23 10-17-2011 08:12 AM
Idle problems need some help stangrunner 1979-1995 Mustang GT 6 09-16-2011 08:49 PM
Y2k v6 idle problems 6Banger2000 2005-2010 V6 Mustang 4 07-22-2011 08:10 AM
Idle problem Stang.racr 1979-1995 Mustang GT 8 07-05-2011 07:19 PM
02:59 PM
