Its alive,, finally - Mustang Evolution
Old 10-27-2011, 11:25 PM   #1
Tj88mustang's Avatar
Its alive,, finally
It's a little update.. Just finished the heater core, the radiator went in pretty smooth and the fans cycled!!! we're off to get tires tomorrow. Woooooooohhooooooo!!!
ID:	33643   Click image for larger version
ID:	33645   Click image for larger version
Tj88mustang is offline   Reply With Quote
Old 10-28-2011, 01:07 AM   #2
Fox5.0's Avatar
How long the heater core take looks great nice stang
Fox5.0 is offline   Reply With Quote
Old 10-28-2011, 02:10 AM   #3
About 4 1/2 all together
Old 10-28-2011, 02:34 AM   #4
Alright guys so here's my next surprise my stang has revealed. I know 88 didn't have MAF mine does so here is what the computer was out of (see pic) the car does slightly searches for idle but still feels ridiculously fast.. So i don't think its really affecting its performance .Is there something going on with this ECM that I might have to do to get it to smooth out or is that normal with the MAF swap.
ID:	33656   Click image for larger version
Old 10-28-2011, 10:09 AM   #5
mike hawk's Avatar
Wats up man.... I no im kinda jumping to ur thread.butt as I was reading i realized that my 88 also has a maf... Why would u even do the swap??? Dose it improve anything?
mike hawk is offline   Reply With Quote
Old 10-28-2011, 10:16 AM   #6
As far as I know this year doesn't have MAF. I think it allows the air/fuel/spark to better adjust Don't quote me on that. But that's my understanding lol. If yours has it already I'm guessing you have a newer year ECM in yours also. Any idle issues?
Old 10-28-2011, 11:20 AM   #7
93slowstang's Avatar
Your tps may be out of adjustment or you may just need to set your idle. Where abouts is it idling.
Old 10-28-2011, 12:07 PM   #8
Re: Its alive,, finally
You will need to get some driving time in to let the ECU/ECM "learn" its operating parameters. Usually 20-30 miles is sufficient.
Old 10-28-2011, 12:09 PM   #9
All 88 Mustangs manufactured for use in California were MAF instead of speed density.
MAF is much more forgiving when modifying the engine.
Speed Density is really sensitive to camshaft changes.
Old 10-28-2011, 01:13 PM   #10
@93 it's at 800ish it just searches 1200-800 randomly.. Thanks for the info Trojan my ECM as in the pic says 92 gt maf so it's def not Cali car Lol. But tires tomorrow so I'll put the miles on it to see if it clears up. It developed a pretty hefty valve tick on drivers side are the stock vslves adjustable? Or is there another surprise awaiting hopefully not bad...
---------- Post added at 05:13 PM ---------- Previous post was at 05:00 PM ----------
How do you adjust Tps?
Old 10-28-2011, 01:33 PM   #11
Here is a guide for you. http://www.muscularmustangs.com/tps.php
Old 10-29-2011, 06:59 PM   #12
Thanks @93 I'm replacing all the vacuum hoses tomorrow then I'll go from there (simple first) lol
Old 10-29-2011, 07:31 PM   #13
No problem, any more questions let us know.
Old 11-11-2011, 09:56 AM   #14
Hey guys little update all vacuum lines replaced still searched for idle. Replaced IAC same result lower idle, replaced and set TPS, sweet spot idling perfect. Doing springs, wheel bearings, inspection, and done till the hood gets here next week. Stoked!
Old 11-11-2011, 11:07 AM   #15
Glad to hear its back up and going.
Old 11-11-2011, 11:09 AM   #16
stampde's Avatar
+1 , well said
2011 GT Auto
dad finally gave up the keys jcford New Member Introductions & Greetings 37 11-19-2011 10:36 AM
Finally got to the track =( 04machazblue 1979-1995 Mustang GT 55 11-01-2011 10:18 PM
Finally bought my new 2004 TheJigShow 1996-2004 Mustang GT 21 10-04-2011 06:52 PM
suspension is finally installed! tigercrazy718 2005-2010 Mustang GT 8 08-18-2011 11:09 PM
its alive!!! svtlx 1979-1995 Mustang GT 19 07-25-2011 12:04 PM
10:22 PM
