2nd and 3rd whine - Mustang Evolution
Old 10-28-2011, 06:48 AM   #1
jwhayne0001's Avatar
2nd and 3rd whine
After installing the pro 5.0 shifter, ive noticed 2nd and 3rd have a loud whine, i adjusted the stops per instructions, could this be caused from where i had to cut the rubber seal to fit around the shifter. Thanks!
jwhayne0001 is offline   Reply With Quote
Old 10-28-2011, 07:11 AM   #2
Re: 2nd and 3rd whine
its because the shifter design allows for the sounds/vibration to travel up through the shifter, just part of it. Seems steeda is bad about it as well. The best on noise is MGW, but you can get some shifter gaskets and it can help some or a little dynomat.
Old 10-28-2011, 07:16 AM   #3
Ok thanks for the reply i just wanted to make sure it wasnt gears not meshing properly
Old 10-28-2011, 07:26 AM   #4
I would personally just remove the shifter stops, they are not needed as it has internal stops. At least back them WAY out.
Old 10-28-2011, 07:41 AM   #5
I thought that was the whole purpose to install a A/M shifter was to have stops?
---------- Post added at 07:41 AM ---------- Previous post was at 07:41 AM ----------
And for the short throw
Old 10-28-2011, 11:42 AM   #6
Do WHAT? Surely you jest?
The purpose of the stops on aftermarket shifters is to keep you from bending the shifting forks in the transmission when you are out banging gears.
They are one of the main reasons for installing an aftermarket shifter.
Install and adjust them per the instructions included with your shifter.
Old 10-28-2011, 04:00 PM   #7
+ 1 I agree.factory setups arent designed for the abuse that they see sometimes.the stops give us a little extra protection when slamming the gears.
Old 10-28-2011, 06:11 PM   #8
jhagan1980's Avatar
Isn't that 96+ that has internal stops?
jhagan1980 is offline   Reply With Quote
Alabama Events for 2011 SpectorV Regional Mustang Discussion 5 07-25-2011 08:27 AM
Weekend Activities (July 2nd) SpectorV Regional Mustang Discussion 0 06-30-2011 02:51 PM
07:06 AM
