Chattering shifter at wot - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 10-29-2011, 11:55 AM   #1
Cm644rodrigues's Avatar
Cm644rodrigues is unknown around these parts
M getting a chattering sound from shifterwhen wot throttle at higher toms through all gears. Everything is tight. Have steeds tri ax.
Cm644rodrigues is offline
Old 10-29-2011, 09:22 PM   #2
Senior Member
Trojan Horse is just getting started.
Re: Chattering shifter at wot
You'll have to contact those "toms" and tell them to be quiet.
If your Tri-Ax has steel/bronze bushings where there used to be rubber that would account for noise where there wasn't any before. The steel/bronze bushings transmit more noises than the factory rubber bushings.
If this is occuring after the shifter has been installed for a while, then you need to check the level and maybe change your transmission fluid.
The chattering could be caused by lack of lubricant and heat build up which will eventually kill your transmission.
You also need to check for loose drivetrain components and bad u-joints.
Trojan Horse is offline
Old 10-29-2011, 09:51 PM   #3
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
Do you have your shift lever bushing installed. If that's missing it can cause the chatter.
93slowstang is offline
Old 10-30-2011, 09:46 AM   #4
Should a lever bushing have come with the shifter.
---------- Post added at 09:46 AM ---------- Previous post was at 09:41 AM ----------
Yes they are installed. Is there supposed to be some kind of Teflon bushings that goes between the ball on the bottom of the shifter and where it's accepted in the transmission?
Old 10-30-2011, 10:31 AM   #5
Senior Member
dreamstang is unknown around these parts
This goes on the ball on the end of the shifter
http://www.google.com/m/products?gl=...A&ved=0CB0Q8gI
dreamstang is offline
Old 10-30-2011, 10:47 AM   #6
Moderator
Yes
Old 10-31-2011, 08:23 AM   #7
Terminator Owner
SpectorV is just getting started.
you sure its the shifter, does it sound like marbles bouncing around, could be detonation
SpectorV is offline
Old 10-31-2011, 04:11 PM   #8
Sort of sounds like marbles. What should I check if it's detonation
Old 10-31-2011, 04:16 PM   #9
Senior Member
start with timing.
Closed Thread
T-5 shifter bushing jwhayne0001 1979-1995 Mustang GT 12 10-22-2011 10:38 AM
New shifter 11stangGT 2010-2014 Mustang GT 39 10-10-2011 07:35 AM
auto shifter cable to steering wheel. Black_Sunshine Pre-2005 V6 Mustang 4 10-02-2011 06:54 AM
Short Throw Shifter bmabbott Pre-2005 V6 Mustang 11 08-17-2011 03:03 PM
Shifter advice Qwik Four Six 1979-1995 Mustang GT 8 07-08-2011 08:58 AM
01:00 AM
