Update - Page 2 - Mustang Evolution
Old 11-14-2011, 04:19 PM   #36
04machazblue's Avatar
Originally Posted by Trojan Horse
If you want to know what your actual temperature is, I would.
I got a 160 and on the highway it stays just above 130 and idle goes up a tad bit but takes a Lil for the heat to kick in =\
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 11-14-2011, 04:28 PM   #37
That is to cold.
Old 11-14-2011, 04:51 PM   #38
Re: Update
Yes it is to cold.
It is not getting up to the operating temperature needed by your ECU to take it out of cold run loop, plus if your oil isn't getting up to at least 180 degrees it is not lubricating properly and you will end up wiping out your bearings.
Your car will run better and probably use less fuel if you remove that 160 and put at least a 180 in it.
Old 11-14-2011, 06:55 PM   #39
351mustang's Avatar
Well I think my issue with the fuel problem maybe my alternator. On start up I'm at like 10 volts
351mustang is offline   Reply With Quote
Old 11-14-2011, 08:15 PM   #40
Re: Update
I guess it could be if the pump (electric?) is not getting enough voltage.
I'm surprised it will even start the car at 10 volts.
Make sure your engine grounds are good and fully charge the battery.
Low volts can ruin some engine electronics.
When an alternator is working properly it should put out around 14 volts for a short while after start up.
Old 11-14-2011, 08:40 PM   #41
351mustang's Avatar
I'm going to get a volt meter tomorrow to get a more accurate reading and yes it is electric
Old 11-18-2011, 01:18 PM   #42
351mustang's Avatar
Well I have narrowed it down to a electrical issue if that makes any sense. It's either the alternator or a loose connection some where and I think the starter maybe going. I drove it a couple days ago it started sputtering and jerking shut off. Tried to start it nothing not even a click. Pushed it about a half mile got back in it and it starts right back up. It did not want to keep running but I got it home. Any ideas?
iOS 5 App Update Brent ME Site Help & Announcements 2 10-20-2011 12:53 AM
iphone update 5.0 00STANG00 The Bar 12 10-14-2011 12:30 PM
new app update bradh2414 ME Site Help & Announcements 9 10-04-2011 11:22 AM
Alabama SouthernStang Weekend Update 8/6/11 SpectorV Regional Mustang Discussion 0 08-05-2011 09:34 AM
SouthernStang Weekend Update 7/30/11 SpectorV Regional Mustang Discussion 1 07-31-2011 07:19 PM
05:31 PM
