Update - Mustang Evolution
Old 10-31-2011, 06:36 PM   #1
351mustang's Avatar
Update
Kind of got behind schedule but here are some update photos since the last time all the accessories are on and the hood. Hopefully soon I can update with a video of it running
ID:	33816   Click image for larger version
351mustang is offline   Reply With Quote
Old 10-31-2011, 08:15 PM   #2
Looking clean man! Keep up the good work.
Old 10-31-2011, 08:25 PM   #3
SleepingStang's Avatar
Very clean engine. Nice job.
SleepingStang is offline   Reply With Quote
Old 10-31-2011, 08:34 PM   #4
TrickFlow94's Avatar
Very clean! Nice work!
TrickFlow94 is offline   Reply With Quote
Old 10-31-2011, 11:23 PM   #5
Re: Update
Nice job! Looking forward to hearing it run.
Old 11-01-2011, 03:43 PM   #6
351mustang's Avatar
Well it's up and running and driving. Im supposed to make it over there tomorrow night hopefully I can get some video. Builder said its running very well, however the brake line rotted out and I need a adjustable quadrant any suggestions?
Old 11-01-2011, 04:42 PM   #7
Re: Update
Here you go from our site sponsors.
Let them know you are a member here and you may get a discount.
LRS Adjustable clutch cable kit
AM Adjustable clutch cable kit
Old 11-01-2011, 04:54 PM   #8
351mustang's Avatar
So should I call when I order?
Old 11-01-2011, 05:26 PM   #9
Re: Update
You can do that or ask them or look for information on their forums.
AM Forums
LRS Forums
Old 11-01-2011, 05:30 PM   #10
351mustang's Avatar
AM Forums
LRS Forums
I called they said something about the forum moderator should give you the coupon code that was AM. He said they still would give it to me then my phone cut out :sigh:
Old 11-01-2011, 05:39 PM   #11
Re: Update
Look on the links I gave you.
The code is in LRS forum and instructions are in the AM forum.
Then you can just order what you want online.
Old 11-01-2011, 05:54 PM   #12
deadsp0t's Avatar
Looks real clean! I like it! You have a thread with the engine build info?
That's unimpressive
Old 11-05-2011, 10:52 AM   #13
351mustang's Avatar
http://cfs-p2.l3.fbcdn.net/353517/64...4.facebook.com
Finally started
Old 11-05-2011, 10:54 AM   #14
skyline247's Avatar
Sounds great!
1988 GT - Stock
*SOLD* 2012 GT Premium, Black on Black, 3.55 Axle, HID and Security Package, Pypes Pype Bomb Axle Backs
skyline247 is offline   Reply With Quote
Old 11-05-2011, 10:55 AM   #15
Sounds like you got it running pretty good.
Old 11-05-2011, 10:55 AM   #16
deadsp0t's Avatar
Nice!
That's unimpressive
Old 11-05-2011, 11:07 AM   #17
351mustang's Avatar
Still needs some tuning
Old 11-05-2011, 11:33 AM   #18
Re: Update
Sure does feel good when you get to hear them run for the first time eh?
Old 11-05-2011, 07:09 PM   #19
351mustang's Avatar
Feels real good now only if I can get it on the street
Old 11-05-2011, 07:16 PM   #20
93slowstang's Avatar
I know you're anxious to drive it. Sounds good.
Old 11-05-2011, 07:35 PM   #21
351mustang's Avatar
Understatement lol it's been over a year of waiting
Old 11-05-2011, 09:56 PM   #22
I bet, over a year is probably a nerve wrecker.
Old 11-11-2011, 04:02 PM   #23
351mustang's Avatar
Taking the car for its first spin tomorrow. I'm in luck high of 55 sunny( I'm in Michigan )
Old 11-11-2011, 04:29 PM   #24
Have fun and be careful.
Old 11-12-2011, 02:04 PM   #25
351mustang's Avatar
http://video.ak.fbcdn.net/cfs-ak-ash...639820249d5cda
Old 11-12-2011, 02:24 PM   #26
deadsp0t's Avatar
Good stuff man! Sounds tough!
That's unimpressive
Old 11-12-2011, 05:31 PM   #27
Sweet!!!!
Old 11-14-2011, 09:02 AM   #28
351mustang's Avatar
Just want to run something by you guys. I'm only getting 3psi for fuel pressure at idle. I should be around 6 or 7. I order a new fuel pump. However here is what happens I start it up runs for a bit shuts off.. Start it up again shuts off. On the third startup it runs fine I take off shuts down while driving does that maybe 2 more times also I'm not having issues with restarting it but by the 5th time it's running fine. I also may be experiencing some charging issues. What do you guys think?
Old 11-14-2011, 09:42 AM   #29
Re: Update
Yeah the fuel pressure should be in the 5-8 psi range. Check your fuel bowl levels.
Also, if you change out the needle and seats in the carb (or maybe it already has them?) for the higher pressure versions it may benefit you if your line size is marginal.
When it shuts off is it instant like turning off a key or does it sputter like fuel loss?
Old 11-14-2011, 10:02 AM   #30
351mustang's Avatar
It sputters tries to go but then it just shuts off and I'm coasting.
Old 11-14-2011, 10:45 AM   #31
Re: Update
That sounds like a fuel delivery problem.
Like I said check the fuel bowl levels amd you may have a sticking needle and seat issue too.
You used to be able to get clear float bowl level checking screws which made checking the fuel level really easy and quick to do, but I don't know if they are available nowadays or not.
Old 11-14-2011, 11:06 AM   #32
351mustang's Avatar
Alright thanks for the help. Also what's the normal temp on. The foxes it's kind of strange that the temp gauge says normal all the way up to the 237 mark.. I have the 140mph cluster
Old 11-14-2011, 12:28 PM   #33
Re: Update
Not sure what you are asking?
I put a 180 degree thermostat in mine and it runs around 190-195 degrees. I put a small thermometer in the thermostat elbow on the intake, because I don't think the factory gauge is very accurate. It runs in between the R & M on the instrument panel gauge.
In my experience Fords run better if they don't get too hot.
Old 11-14-2011, 12:48 PM   #34
351mustang's Avatar
So I should probably look into getting an aftermarket temp gauge?
Old 11-14-2011, 12:54 PM   #35
Re: Update
If you want to know what your actual temperature is, I would.
iOS 5 App Update Brent ME Site Help & Announcements 2 10-20-2011 12:53 AM
iphone update 5.0 00STANG00 The Bar 12 10-14-2011 12:30 PM
new app update bradh2414 ME Site Help & Announcements 9 10-04-2011 11:22 AM
Alabama SouthernStang Weekend Update 8/6/11 SpectorV Regional Mustang Discussion 0 08-05-2011 09:34 AM
SouthernStang Weekend Update 7/30/11 SpectorV Regional Mustang Discussion 1 07-31-2011 07:19 PM
10:09 PM
