sct 4 bank eliminator chip - Page 3 - Mustang Evolution
Old 11-16-2011, 07:37 AM   #71
KATO's Avatar
Re: sct 4 bank eliminator chip
07 GT. SCT: CUSTOM TUNE by "MUSTANG SPECIALTIES". LMR: GEN2 2010 STYLE HEADLIGHTS, RAXIOM: 2010 SMOKED COYOTE TAIL LIGHTS, WHEELS: STAGGERED WHL 22X8.5F-22X10R.
Old 11-16-2011, 01:17 PM   #72
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Originally Posted by Tj88mustang View Post
Getting mine Thursday with a dyno tune at BNT performance can't wait!!!!
Awesome!
Good luck! I'm sure you will love the new-found performance!
Old 11-18-2011, 10:19 AM   #73
Tj88mustang's Avatar
Love the Sct chip car runs so smooth
Must say I was expecting just a tad more hp but still very satisfied well worth the money and it solved all my erratic idle issues😃
Tj88mustang is offline   Reply With Quote
Old 11-18-2011, 07:15 PM   #74
AmericanMuscle.com
Sponsor
That's great! Glad you like it! Thanks for posting up your experience with the chip!
Did you use our tunes, or no?
Old 11-18-2011, 08:00 PM   #75
88fox's Avatar
I'm not very familiar with chips and tuners but am interested
88fox is offline   Reply With Quote
Old 11-19-2011, 06:59 AM   #76
Custom tune that he did on the dyno. We talked heads, upper/ lower intake, custom cam etc. we'll get there 😉
Old 11-20-2011, 02:25 PM   #77
AmericanMuscle.com
Sponsor
They are definitely worth the money. They will be the tool that ties all of your modifications together and get you the best performance/driveability. Without one, you really are missing out on the car's true potential.
Please feel free to contact our tuning specialists directly to find out what a tune could do your for application! You can call them at 888-226-9764 or via email at bama@americanmuscle.com.
Okay, cool! Well, if I can be of assistance in the future, please don't hesitate to ask
Old 11-20-2011, 02:49 PM   #78
Actually I do have a quick? I talked to my tuner (Shawn) at BnT he said I could still play with the timing even with the chip. He said it was a very smooth curve on the dyno So he didn't mess with it. Any thoughts? Should I mark where it is now and then put it at 14 degrees and try it? Or does the chip totally control it?
Old 11-20-2011, 03:37 PM   #79
AmericanMuscle.com
Sponsor
You should be able to manually command timing as well, yes, but it really depends upon what timing your tune is currently running. If it is conservative and you are still making good power/the car is very driveable, I would just leave it as such. You start messing with aggressive timing and that's when you lean-out/detonate or just start to have driveability issues.
I would check what the timing is now and go from there!
Old 11-20-2011, 04:29 PM   #80
Schlahty's Avatar
Region: Oregon
American muscle told me there 99% sure my SCT chip has nothing to do with my shift points. New tps. Drives well wile manually shifting. Fresh trans rebuild. Any thoughts
Schlahty is offline   Reply With Quote
Old 11-21-2011, 06:16 PM   #81
AmericanMuscle.com
Sponsor
Do you have an upgraded rear-gear in the car?
If so, that will definitely cause the transmission to shift irregularly, especially if the PCM is not tuned for the gears.
What shift kit is on the car?
Old 11-21-2011, 08:58 PM   #82
Schlahty's Avatar
Region: Oregon
Yes. 4.10s I told the tranny guy I had them. I'm going to bring the car in next week. That's the main reason I had the tranny changed, cause of the new gears. It was on its last leg.
---------- Post added at 09:58 PM ---------- Previous post was at 09:56 PM ----------
PCM. What is that exactly? Does my SCT chip have anything to do with shifting? Seems like it would considering it shifts different in each mode.
Old 11-22-2011, 01:30 PM   #83
AmericanMuscle.com
Sponsor
Okay, yea, I would just double-check with them that the tranny is set up for 4.10s. From there, you need to tune the PCM(Powertrain Control Module{the computer that controls the car}) to be set for 4.10s as well, because otherwise the PCM will want to shift on the same settings for stock gears. If you upgrade the gear, you have to let the PCM know(via the 4-bank eliminator chip) that the rear gear is not stock and so the shift-points will need to be adjusted.
I hope this helps!
Please let me know if I may be of assistance in the future!
Old 11-29-2011, 06:17 AM   #84
Schlahty's Avatar
Region: Oregon
The chip was tuned for the 4.10 gears, only thing new after chip tune was the tranny rebuild. Tourque converter and shift kit are the only things new to the car after I installed the chip. It's outa my hands for a few months. I hope they figure it out. Already 2400 into transmission
---------- Post added at 07:17 AM ---------- Previous post was at 07:09 AM ----------
Dyno tune. SCT dealer. Got a lead.
Old 11-30-2011, 04:15 PM   #85
AmericanMuscle.com
Sponsor
What torque converter stall speed are you using? Depending upon what you are running, you may need to have your tune adjusted so the transmission isn't freaking out with the new TQ converter installed.
By your update, it sounds like you're getting a dyno tune. If so, please let us now how it goes and please let me know if I may be of further assistance in the future! Good luck!
Old 04-01-2014, 09:53 PM   #86
sct 4bank
just got my car together as i was building it and installed chip with selector and my car runs terrible on any selection other than stock configuration . on st, per, and race car idles 1500 or higher and cant adjust throttle any lower as well as i have all kind of pinging going on. i know its not valves just installed new heads machined and ready with new valve springs rockers etc. what could be wrong
iivey is offline   Reply With Quote
Old 04-01-2014, 10:46 PM   #87
slade95gt's Avatar
Are the wot boxes effective on 95 and older 5.0's I've heard from some people they are for modular cars and from others (very few ) that they can work on our cars..... Anyone have experience in this? They 2 stage launch control would be awesome but I'm more interested in the no lift shift feature..... Any feedback would be awesome
slade95gt is offline   Reply With Quote
Old 04-01-2014, 11:00 PM   #88
does anyone know if there is a way to log into bama to view personal tune.
Old 04-02-2014, 08:52 AM   #89
slade95gt's Avatar
I know u can email them
Old 04-02-2014, 05:25 PM   #90
Hey, Dan with AM. Does the SCT chip have any parameters for the auto trans? Can it firm up shifts or changing shift points? I put in a 4r70w trans in my 95 GT and would like to make some changes
Jim
Vettn71 is offline   Reply With Quote
Old 04-02-2014, 09:18 PM   #91
slade95gt's Avatar
The bama chip is loaded with custom tunes for your car..... U tell them what mods u have on your car and what your wanting then they write custom tunes for your specific needs and yes they can absolutely stiffen up and change shift points
SCT? back n a stang 2011-2014 Mustang GT 37 10-25-2011 06:19 PM
1994-1995 sct tuner f/s deadsp0t Mustang Parts for Sale and Wanted 1 10-03-2011 01:48 PM
Used SCT Tuner cks0925 Pre-2005 V6 Mustang 5 09-15-2011 08:29 PM
Any of you guys with SCT Tuners might want to read... illestdomer2005 2011-2014 V6 Mustang 15 09-12-2011 11:03 PM
Sct from american muscle nickysixx 2005-2010 Mustang GT 10 06-25-2011 07:33 PM
07:29 AM
