need some advice starting issue - Mustang Evolution
Old 11-02-2011, 10:24 PM   #1
04machazblue's Avatar
okay sowhen i go to start my car it wil start and the bog down try to go back in rpms then come back down and stall.... then i go to start it again give it some gas hold the gas for a couple seconds at like 1500rpms and then the car will idle. can someone lead me in the right direction btw there are now engine codes
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 11-02-2011, 10:55 PM   #2
Re: need some advice starting issue
Sounds like you may have a fuel supply issue.
Have you checked your fuel pressure?
Replaced filter?
Can you hear the fuel pump running?
Does the engine turn over normally when trying to start?
Please, give as much information as you can, no matter how insignificant it may seem.
Old 11-03-2011, 07:29 AM   #3
KATO's Avatar
I agree with Trojan, there is definately something else going on with your car. The Fuel is the best place to start. What Octane gas are you using also?
Old 11-04-2011, 08:45 AM   #4
Okay I can hear the fuel pump running its a 190lph Holley and my fuel pressure is 38psi and the filter not to sure of I should check it I was just on my way to work and I got on it a little and when I slowed down quick it cut off on me. Started it up and had to keep giving it gas to keep it running after about 10 second of feathering the throttle it idled but when u I let go if the gas it dropped rpms and came up
And did it again then leveled out
Old 11-04-2011, 08:58 AM   #5
KATO's Avatar
Definately check that Filter.
Old 11-04-2011, 09:16 AM   #6
That's strange.
It almost sounds like when you slowed down quickly that maybe you sucked some debris into the fuel system, sloshed what was in the filter over the inlet or outlet or (I don't even know if this is possible for sure.) partially or temporarily activated the inertia switch.
Old 11-04-2011, 09:20 AM   #7
Hmm also when I shut the car off the fuel pressure should drop
To zero but it takes for ever for the gauge to go down and it's a newer gauge I swapped out the old one
Old 11-04-2011, 09:36 AM   #8
It should hold pressure for awhile.
If it drops quickly then you have pressure regulator problems.
Old 11-04-2011, 10:30 AM   #9
stampde's Avatar
Filter, filter,filter
a
2011 GT Auto
Old 11-05-2011, 10:37 AM   #10
I recently purchased some more Mustang Tech books and while reading through one of them I ran across Deceleration Control Strategy.
The book says that your IAC (It took me a while to figure this out, because they call it a BPA, "Bypass-Throttle Air") controls this strategy to keep your engine from stalling from sudden cut-off the air supply, i.e. suddenly letting off the gas pedal.
So you may want to make sure your IAC is clean and working properly.
Old 11-05-2011, 10:47 AM   #11
the iac is brand new got it from the parts store alsothe issue is when u start the car when its warm it wont stay running with out giving it a little gas i can hear the iac working when i truen the key into the on posistion andhad it off tomake sure
Old 11-05-2011, 11:30 AM   #12
Ok, I thought I might have lucked into a cure for you.
I'll keep looking and we'll find a solution eventually.
Old 11-05-2011, 01:14 PM   #13
Thanks I hope to find a solution soon myself
mustang drivability issue wss003 1979-1995 Mustang GT 2 11-02-2011 08:14 PM
starting problem chuck andres 1979-1995 Mustang GT 13 10-11-2011 07:24 AM
gauge issue mrc 1996-2004 Mustang GT 3 09-13-2011 08:14 AM
Advice 89white GT General Car Discussion 11 08-17-2011 03:38 PM
Rear end advice t0t4lbl4ck0ut 1996-2004 Mustang GT 6 08-07-2011 06:59 PM
02:27 AM
