Timing advance - Mustang Evolution
Old 11-05-2011, 08:01 AM   #1
jwhayne0001's Avatar
Timing advance
I already run premium gas anyways, but does advancing the time 4 degrees in my cobra really make for a big performance gain?
jwhayne0001 is offline   Reply With Quote
Old 11-05-2011, 09:40 AM   #2
deadsp0t's Avatar
Yes. Is the short answer.
---------- Post added at 11:40 AM ---------- Previous post was at 11:39 AM ----------
It will wake it up! If you have a chip it might be best to leave it be.
That's unimpressive
Old 11-05-2011, 10:31 AM   #3
No chip, just debating to crank it up or not
Old 11-05-2011, 10:45 AM   #4
deadsp0t's Avatar
It's free HP for a push rod motor. It can be advanced w/o using a light, 4 degrees is not a lot at all and you WILL be surprised at the difference. If you get any 'pinging' sound just turn it back a little. I've herd ppl claim as high as 16 degrees. Though 12-14 is more common.
That's unimpressive
Old 11-05-2011, 10:46 AM   #5
It's free hp.the cheapest you'll find.with base timing and no tune/chip it is not benefiting you running premium fuel.
Old 11-05-2011, 10:59 AM   #6
Re: Timing advance
Advancing the timing will definitely help.
It will provide you with quicker, smoother acceleration.
Just be sure you don't advance it to much, keep your ear tuned for any indication of detonation.
I advance mine until I hear it beginning to spark knock/detonate, then I back it off 1-2 degrees from that point.
From then on just be alert for any signs of detonation that could be caused by temperature or humidity changes or differences in fuel quality.
On my first car, when I was tuning the timing,
(Note: This was when you could get "real" high octane fuel from the gas pump or your local small airport and I didn't have any fancy tools such as a timing light to work with. )
I would advance it until I could hear it detonate, then back it off the 1-2 degrees and go out and make a high speed, high RPM run. If it did not miss at high RPMs I was good to go, if it did I had to back it off 1-2 more degrees and make another run.
During one of those "tuning" runs I went past a Highway Patrolman running 80+ MPH in a 45 MPH zone.
I did get away that evening, but he got me the next day. Perils of living in a small town where everyone knows you.
Old 11-05-2011, 11:04 AM   #7
Re: Timing advance
I think he is talking about 4 degrees in addition to the stock 10 degrees which would put him at 14 degrees initial timing.
When people claim advancements up to 12-16 degrees they are talking about advancing the timing 2-6 degrees over the factory 10 degrees setting, not 12 to 16 degrees over the initial 10 degrees which would put them at 22 to 26 degrees timing which is way too much.
Old 11-05-2011, 11:10 AM   #8
deadsp0t's Avatar
Right, I was talking about actual movement of the distributor in the engine. Hope I didn't confuse anyone
That's unimpressive
Old 11-05-2011, 02:39 PM   #9
Well i advanced it, at first it was too much, alot of spark knock at WOT, backed it down 2 degrees, and now 1st and 2nd feel alot more robust and better mid range power
Old 11-05-2011, 02:54 PM   #10
deadsp0t's Avatar
+1
That's unimpressive
Old 11-05-2011, 04:01 PM   #11
Cool!
Old 11-07-2011, 07:27 AM   #12
Re: Timing advance
for me every 1 deg is about 10rwhp (@93 oct)~ but you do not want detonation~ not sure on an N/A car
Old 11-07-2011, 03:24 PM   #13
wc3john's Avatar
Re: Timing advance
I have 15 degrees of advanced timing and I have a bama tuned sct chip. I run 93 all the time and have no issues what-so-ever...
and the motor is Hell bent on beating any gm product at the track lol
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 11-07-2011, 04:07 PM   #14
deadsp0t's Avatar
15 degrees with the chip, or 15 plus whatever chip does..?
That's unimpressive
Old 11-07-2011, 04:24 PM   #15
jhagan1980's Avatar
So, if I have a SCT chip I shouldn't mess with the timing then?
jhagan1980 is offline   Reply With Quote
Old 11-07-2011, 04:42 PM   #16
deadsp0t's Avatar
Mine ran like sh*t with the timing up(that way when I bought the car) put back base and it works great!!!
That's unimpressive
Old 11-07-2011, 05:34 PM   #17
wc3john's Avatar
Re: Timing advance
Depending on your tuner. I know my bama chip, when ordered, told me to leave timing at 10 degrees advanced. Whether or not the comp advances it more I dont know. I recently checked the timing on my motor and its at 15 degrees advanced. ( only because I didnt have the chip on the car at the time I put the cam in and it wouldnt run without it advanced so)
Once I put the chip on, I simply forgot to ****** the timing but since it hasnt blown up in the last 3 months, I've simply left it.
---------- Post added at 06:34 PM ---------- Previous post was at 06:32 PM ----------
15 degrees according to the harmonic balancer with the vaccuum advance pulled off.
I dont know if the chip messes with timing or not
Old 11-07-2011, 05:41 PM   #18
deadsp0t's Avatar
Yes the chip controls the timing and likely negates where ever the distributor is set.
That's unimpressive
Old 11-07-2011, 05:48 PM   #19
93slowstang's Avatar
The chip doesn't affect base timing. When you plug the spout connector back in then it's in control.
Old 11-07-2011, 05:53 PM   #20
deadsp0t's Avatar
+ exactly
That's unimpressive
Old 11-07-2011, 06:05 PM   #21
jhagan1980's Avatar
Well I have no idea what my timing was at when I got my car. I had a SCT chip installed with a Dyno tune so I wasn't sure if I should advance it if it wasn't or if the chip controls it.
Old 11-07-2011, 06:18 PM   #22
deadsp0t's Avatar
It should likely be set at the base +10 marks then let the chip control it.
That's unimpressive
Old 11-07-2011, 06:35 PM   #23
Filibuster
I advanced my timing 4° so im at +14 right now...+10° is stock for my 89..
XXSTEVEO66 is offline   Reply With Quote
Old 11-07-2011, 08:46 PM   #24
deadsp0t's Avatar
Right. What we are saying is with a chip like the SCT 4bank timing should be at base before installing the chip, and let the ECU control any advancement of the timing.
That's unimpressive
Old 11-08-2011, 07:42 AM   #25
Filibuster
Ohhhhh derp....ok then!...yeah what he said!..
Old 11-09-2011, 05:55 PM   #26
94 Mustang GT's Avatar
Also have to disconnect the spout connector otherwise the computer will compensate as much as possible!
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Timing!! 89 Foxloco 1979-1995 Mustang GT 7 10-11-2011 08:04 PM
Timing advanced. 89 Foxloco 1979-1995 Mustang GT 1 09-25-2011 02:20 PM
Need help with timing cover bolts WhiteCobra94 1979-1995 Mustang GT 33 08-11-2011 02:23 PM
advancing timing 5.slow 1979-1995 Mustang GT 6 08-10-2011 10:40 AM
timing gear drive peoblem? C4king 1979-1995 Mustang GT 8 08-09-2011 08:54 PM
09:49 AM
