Cleaning heads - Mustang Evolution
Old 11-05-2011, 09:54 AM   #1
Cm644rodrigues's Avatar
Cleaning heads
Ust picked up a set of 351 heads. They need to be cleaned and rebuilt. What would be the best cleaning solution.
Cm644rodrigues is offline   Reply With Quote
Old 11-05-2011, 10:12 AM   #2
SleepingStang's Avatar
Best bet for a complete clean is to disassemble at home and have them dipped at a machine shop. You could spend a lot of time at home cleaning them yourself and never get as clean as a dip. IMO if you are going to do anything with an engine you should start out with the cleanest pieces you can.
SleepingStang is offline   Reply With Quote
Old 11-05-2011, 10:45 AM   #3
I agree about cleanliness . What's the going rates for dips at shops?
Old 11-05-2011, 11:37 AM   #4
You would have to check with your local shop, but I paid $40 about 3 years back. I know I had a bunch of work done at the same time though. You may want to have them go through the heads while they have them and check valve seats and seals. This would ensure that you are getting a good set of heads. If you already are certain they are good then maybe just the cleaning. The dip is nice as opposed to a steam clean because it gets in all the coolant passages and cleans out all that gunk too. It also provides an excellent base for painting.
Will GT40 Heads Handle A Big Cam?? 90Stang_5.0 1979-1995 Mustang GT 27 11-02-2011 03:12 AM
E7 heads or Gt40 heads? Qwik Four Six 1979-1995 Mustang GT 18 10-29-2011 09:59 PM
Cylinder heads 89white GT 1979-1995 Mustang GT 15 09-13-2011 10:12 AM
Can you put Cobra heads on a GT Mustang? FORDGT14 1996-2004 Mustang GT 12 09-13-2011 10:06 AM
Cumbustion chamber size Mustang1968kr 1979-1995 Mustang GT 2 08-23-2011 11:51 AM
08:34 AM
