header gasket...agian:( - Mustang Evolution
Old 11-05-2011, 12:01 PM   #1
mystang50's Avatar
i think my header gasket has blown again...damn its a hassle this is second time its done it sence my shorty install...on passanger side why does it keep blowing??
Old 11-05-2011, 12:06 PM   #2
deadsp0t's Avatar
I used copper gaskets when I did mine w/ no issues. Also if the flanges have weld trash on them it can cause issues. I filed my flanges down, and knocked down the weld in the tubes too.
That's unimpressive
Old 11-05-2011, 12:12 PM   #3
Re: header gasket...agian:(
Copper gaskets and cleaning up the header surface is very good advice.
I have also used a thin coat of Permatex Ultra Copper silicone over both sides of the paper gaskets with good results. Just let the silicone dry completely after spreading it on the gasket with your fingers and lightly grease the header and head surfaces when installing. The grease allows the gasket to move around a bit during installation to keep from tearing the coat of silicone.
Old 11-05-2011, 12:19 PM   #4
deadsp0t's Avatar
Took me a long time to install mine, and it was a real pain. I had herd the horror stories of blown gaskets and $25 bucks for copper gaskets is a small price for piece of mind.
That's unimpressive
Old 11-05-2011, 12:20 PM   #5
mystang50's Avatar
details plz...where did u get them??
Old 11-05-2011, 12:26 PM   #6
deadsp0t's Avatar
When I bought/traded for my headers at FastLane(a speed shop) I ordered them there. Any speed shop can get them for you, maybe the parts store too. I'd have to look but I'd guess AM.com has them too.
---------- Post added at 01:26 PM ---------- Previous post was at 01:23 PM ----------
Mine were Mac brand, they used to advertise them in the Mac ad in MM&FF.
That's unimpressive
Old 11-05-2011, 12:39 PM   #7
Couldn't find them on AM, but LRS has them.
LRS Copper Header Gaskets
Old 11-05-2011, 04:05 PM   #8
deadsp0t's Avatar
Price is a little more then what I paid but that was years ago, piece of mind is not cheap!
That's unimpressive
Old 11-06-2011, 10:58 AM   #9
I went with 7 ply aluminum ones a bit of. Pain to put on but selled them up
tbonestang is offline   Reply With Quote
Old 11-23-2011, 03:07 PM   #10
mystang50's Avatar
Copper header gaskets...fail too thin sealed on head side but not on header side...went with alum...
Old 11-23-2011, 06:01 PM   #11
I'm thinking that you have some other issue than gaskets.
Have you checked the headers and head sealing surfaces for flatness?
I bet that likely the header flanges are warped the way all four cylinders show leakage.
P.S. You can anneal and re-use copper gaskets.
Old 11-23-2011, 06:07 PM   #12
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
I've always had good luck with the advance 9000 something(can't remember exactly) header gaskets, have yet to blow them out. When I took the headers off my 87 gt they still looked like new and had been on the car for 4 years.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 11-24-2011, 07:43 PM   #13
mystang50's Avatar
These gaskets were really thin man, but header looked fine by Jus lookin at it...but they sealed up with alum ones...
Old 11-24-2011, 08:05 PM   #14
deadsp0t's Avatar
What brand name where they? Mine had a raised bead around all the ports that smashed down to seal everything up.
Are they(gaskets) blowing the same place each time?
What about your header bolts, new? Used? Loc-tite of any kind?
That's unimpressive
Old 11-24-2011, 08:22 PM   #15
mystang50's Avatar
They were from lrs...no with tha paper ones it would blow diff places on diff sides...header bolts are tha ones that came with bbk headers I used loc-tite
Old 11-24-2011, 08:24 PM   #16
deadsp0t's Avatar
That's odd! Glad you got it sorted out though!
That's unimpressive
Old 11-24-2011, 08:35 PM   #17
The aluminum gaskets are thicker?
If so, and they seal, then your surfaces are warped, but if they work and you are satisfied then good.
The thickness of the gasket should have no effect on the sealing if your surfaces are true and flat.
Old 11-24-2011, 09:47 PM   #18
mystang50's Avatar
Yeah I agree, but didn't want to get headers machined...but those header gaskets were really thin, more thin than paper material ones
Old 11-24-2011, 11:17 PM   #19
I can understand that. The hassles of R&R just aren't worth it at times.
99-04 V6 HEADER LEAK? CHILE10_STANG Pre-2005 V6 Mustang 18 11-11-2011 03:25 AM
Need locking header bolts! Anyone know where? Benzo 2011-2014 Mustang GT 34 10-26-2011 10:02 AM
Sterring shaft hitting header Chris01 1979-1995 Mustang GT 6 09-21-2011 11:01 PM
Head gasket question ? WhiteCobra94 1979-1995 Mustang GT 17 08-30-2011 10:33 AM
Long tube header install CodyNelson 1996-2004 Mustang GT 12 08-22-2011 06:04 PM
06:48 AM
