weird... - Mustang Evolution
Old 11-06-2011, 05:34 PM   #1
mystang50's Avatar
weird...
so eariler today i started my car and put her in N to roll outa driveway and got to the street and car jus died!!it was something electrical cuz radio and police scanner turned off 2..so i tured key to off postion and turned key to start it and nothing happend not evan my scanner fired up...so i do this 2 more times and same results but after 3 attempts i turned key to off and scanner turns on and so i turned key and car turned over jus fine...my V meter is reading fine everything works(lights, scanner, radio etc.) now dont understand what exactaly happend, could any of u ppl tell me what could of happened for it to do that with no V going to anything...it also rested my radio and that only happens when batt is disconnected...
Old 11-06-2011, 05:45 PM   #2
jwhayne0001's Avatar
Ignition switch?
jwhayne0001 is offline   Reply With Quote
Old 11-06-2011, 05:55 PM   #3
Did any thing work that didn't require the key to be on?
Old 11-06-2011, 06:25 PM   #4
deadsp0t's Avatar
Could be as simple as an ignition switch, or
Ground cable.
That's unimpressive
Old 11-06-2011, 06:37 PM   #5
If things that didn't require key on didnt work it is most likely baterry related.battery, cables, grounds, etc.
Old 11-06-2011, 08:02 PM   #6
Kyle94GT302's Avatar
Defiantly check your grounds and battery cables being tight had this problem on my 94 and ending up being a loose terminals
98 GT- Full PI swap, 93 tune, 3:73 gears,off-road h-pipe,flows, ported plenum and spacer, mac cai, lowered on eibach springs and eibach shocks and struts,spec stage 2 clutch, pro 5.0 shifter
94gt-H,C,I exhaust, eibach suspension--SOLD
Kyle94GT302 is offline   Reply With Quote
Old 11-07-2011, 05:06 AM   #7
mystang50's Avatar
Yeah when I looked under hood one if my clamps to my battery is broke but still on tight...like i might of tightened it to tight at 1 point but.its still on there and every thing
Old 11-09-2011, 12:38 PM   #8
wc3john's Avatar
Re: weird...
my car has done this once... never did find the problem as it hasnt happened again... I blame gremlins in the electrical system
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 11-09-2011, 02:41 PM   #9
Weeg15's Avatar
Yeah I had the same problem when I got my fox and turned out to be the batt terminals tried cleaning them and the car would still be temperamental when trying to start so I just for new terminals and cleaned the wires before hooking up and haven't had a problem yet
Weeg15 is offline   Reply With Quote
weird squeaking noise 86 muscle 1996-2004 Mustang GT 8 10-08-2011 03:23 PM
Weird noise? galindojr24 2005-2010 Mustang GT 9 09-14-2011 09:27 PM
Weird Clunking Noise CodyNelson 1996-2004 Mustang GT 5 08-18-2011 08:20 PM
News of the Weird 99ford The Bar 0 08-12-2011 07:51 PM
Any 2011 AT owners out there -- weird throttle response? illestdomer2005 2011-2014 V6 Mustang 5 07-09-2011 12:36 PM
05:57 PM
