radiator swap Q - Mustang Evolution
Old 11-07-2011, 10:40 AM   #1
mystang50's Avatar
radiator swap Q
Ok its a 95 gt and was wanting to put a Mishimoto radiator on there and was wondering what all parts will be needed like if I need new mounts and all that...
Old 11-07-2011, 11:06 AM   #2
Re: radiator swap Q
You shouldn't need mounts as long as yours are in good shape.
Hoses are a judgment call too.
Old 11-07-2011, 12:00 PM   #3
mystang50's Avatar
Yeah that's what I figured...and ima change my hoses to those silicone red Mishimoto ones....that a good radiator? And also mines a auto and the coolant line Jus below the cap that goes to tranny its leaky not bad but catches my eyes is tha fitting that connects to radiator how would I go about changing that....tha whole line or could I Jus change fitting?
Old 11-07-2011, 05:09 PM   #4
Re: radiator swap Q
I don't know how good the radiator is. It's made overseas I suppose?
If so you know how that goes sometimes.
The leak in your transmission coolant line could be from the line, the fitting on the line or possibly the fitting in the radiator. It may also just be loose?
Check it when you take it out and if the line and fitting looks ok try it on the new radiator.
If you have and know how to use a double flaring tool you could install a new fitting. If not you will have to get a new line.
Old 11-07-2011, 05:38 PM   #5
I have a 4 core misomoto alum Rad in my fox and I love it all you should have to do is take the lines out of the Rad and put a liquid thread sealent on them then boom its all fixed
mustangtommy is offline   Reply With Quote
Old 11-07-2011, 08:40 PM   #6
Re: radiator swap Q
IF those are still made the way I remember them, they are connected with an inverted flare fitting which does not seal on the threads, but on the "flared end" of the tubing itself. Putting sealant on the threads won't help if it is leaking from the flared end.
If the end is cracked or broken you have to re-flare it or replace the line.
Old 11-08-2011, 07:39 AM   #7
mystang50's Avatar
Yeah kinda looks like it, I was lookin at it yesturday and it looks like 5/16 tubing
Old 11-09-2011, 12:35 PM   #8
You know what u are correct I had to cut the tubing and replace the end with a different one
Old 11-09-2011, 02:23 PM   #9
Re: radiator swap Q
Occasionally I get it right.
Old 11-10-2011, 06:09 AM   #10
mystang50's Avatar
Where can I get a fitting? I looked on web yesturday and found nothing...Evan searched for the whole line
Old 11-10-2011, 06:12 AM   #11
mystang50's Avatar
U can see the leakage...
ID:	34120   Click image for larger version
Old 11-10-2011, 06:34 AM   #12
Re: radiator swap Q
That looks like the insert into the radiator is leaking, which may or may not be repairable if the radiator is rotted around the fitting.
A radiator repair shop is going to be your best bet.
May be time to look for a replacement depending on the cost of repair.
Old 11-10-2011, 06:36 AM   #13
Your local auto store should carry them
Old 11-10-2011, 10:47 AM   #14
mystang50's Avatar
Well I'm gettin a new misimoto radiator...
Old 11-10-2011, 06:41 PM   #15
Re: radiator swap Q
Then I would suggest that you don't touch the one you have until your new one arrives. JIC it starts to leak worse and renders the car undrivable.
Old 11-11-2011, 05:11 PM   #16
mystang50's Avatar
Woohoo
Old 11-11-2011, 10:35 PM   #17
Re: radiator swap Q
Woohoo
Hahaha! Don't you just love getting new parts?
Old 11-12-2011, 12:15 AM   #18
mystang50's Avatar
Yup! And I went outa town today and my parents decided to take it to tha shop to get it swaped out and they r paying for it so guess saves me a whole day of working on it
Old 11-19-2011, 11:08 AM   #19
mystang50's Avatar
That new radiator is tha ****. I was driving around last night lookin for trouble and noticed it was on L on gauge (n o r m a l ) so I took it out on a long open road and it cooled down so went back into town and was at red light and gauge was standing straight up light turned green I pulled out and looked down and it was on the L again so I stoped at a gas station cuz I figured fan wasn't working, it was unpluged so pluged it in closed hood and sat in car and it was on the O so it disperse heat pretty Dang well I recommend the misumoto radiator to everyone!
02:30 AM
