Starting my t5 swap thread - Mustang Evolution
Old 11-09-2011, 01:58 PM   #1
04machazblue's Avatar
Hey what's up ladies and gents I am gonna be swapping a t5 into my car very soon doing the pedal assembly this Friday trans next weekend putting a lightened fly wheel king cobra clutch world class t5. I will
Hopefully be posting some pics. I am hoping the end result is a better 1/4 mile time
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 11-09-2011, 04:33 PM   #2
93slowstang's Avatar
Gl with the swap.
Old 11-12-2011, 08:03 AM   #3
Vinnietbird's Avatar
Re: Starting my t5 swap thread
I swapped mine a couple of years ago. It was great for the Thunderbird. I also installed an aluminum driveshaft (cut down and balanced Crown Vic cop car piece). Sweetness.
1988 Thunderbird Sport...GT-40P engine, ported heads,Crane Gold 1.7 roller rockers, TFS-1 cam,Cobra intake,24# injectors,Mass Air, 8.8 with 3.55's, BBK headers, Pypes X-Pipe,40 series Flowmasters,3 row radiator,Taurus fan,17x9 and 17x10 10th ann. Cobra wheels,and more.....
Vinnietbird is offline   Reply With Quote
Old 11-12-2011, 08:28 AM   #4
Yea I did the pedals yesterday that was the part I was concerned about I got it done In like 2 hours out and in wasn't that bad I am doing the trans next
Week at my friends tranny shop, so that way I can use the lift.
Old 11-12-2011, 09:50 AM   #5
stampde's Avatar
aren't you finished yet Joe ???
Don't for get to put a pilot bearing in !!!!!!
I've done that before ,got the flywheel on and realized i forgot the bearing , go over everything twice ,take your time, don't rush , GET 'ER DONE !!!
2011 GT Auto
Old 11-12-2011, 03:55 PM   #6
No not yet I am doing the trans next week can't wait to be hammering the gas and dropping gears going down the road
Old 11-13-2011, 07:00 AM   #7
Double check that you have the list of parts ready to go. Pilot bearing,the two replacement bolts at the top of the bell housing (the other aod bolts will swap,clutch cable,quadrant,and depending on the tranny (if it's used), swap the rear seal now and be done, block plate, The AOD tranny mount will swap over,lower shift boot (you need that), tranny fluid, and then sell the AOD and TV cable to get some funds back.
It took my friend and I about two hours to swap the trannys out. The AOD removal took more time than installing the T-5. It weighs nothing compared to the AOD.LOL.
Old 11-13-2011, 10:24 AM   #8
I am getting all parts of a donor car I already swapped my pedals has the quadrant and I can use all the bolts from aod bellhousing I am ordering all
New flywheel bolts pilot bearing and pressure plate bolts
Old 11-13-2011, 01:11 PM   #9
That's a very good idea.
New bolts are very inexpensive compared to the damage that could be caused by old ones failng. I had an old 73' Maverick that was converted to a manual trans and they had used cheap grade 2 bolts to secure the pressure plate. When they broke it pretty much scrapped the clutch assembly, flywheel and bellhousing. Thankfully nothing came through the floor boards.
Old 11-13-2011, 10:06 PM   #10
I rather do it right the first time u know but I am stoked to get this in I hope it benefits me and my 1/4 mile times
Old 11-13-2011, 10:28 PM   #11
It's a pretty good bet that it will benefit your 1/4 mile times.
Less weight and less power loss than the auto almost guarantees it.
PLUS, they are a blast to drive!
Old 11-13-2011, 10:38 PM   #12
Yea I also got the trans brace from the donor car is there anything else u think I will need I know I am getting the backing plate, bellhousing, flywheel, got a clutch, cable adjuster, billit quadrant, I am getting new flywheel and pressure plate bolts,
Thing I can reuse from the auto are the bellhousing bolts, driveshaft, and that should be all I need
Old 11-13-2011, 11:01 PM   #13
What about the crossmember?
I think (If I remember correctly.) that you can cut the welds loose and reposition it as needed then reweld.
Probably a good idea to change out the fluid too.
Pedal pads in good shape?
I had a clutch pedal with a missing pad smack me in the shinbone once when sidestepping the clutch. Made me almost wet the seat from the pain.
Old 11-13-2011, 11:09 PM   #14
I got a crossmember from a 5speed car and I got the pedals in already
Old 11-13-2011, 11:20 PM   #15
You should be good to go. I can't think of anything you might have left out.
Old 11-14-2011, 04:39 AM   #16
The top two bell housing bolts for the 5 speed are a different length than the top two from the AOD.
Old 11-14-2011, 05:38 AM   #17
So what are u saying they won't fit? Too short to
Long?
Old 11-14-2011, 06:00 AM   #18
blackhawk 1's Avatar
what kind of shift knob are you thinking of?
blackhawk 1 is offline   Reply With Quote
Old 11-14-2011, 06:15 AM   #19
Stock one is fine
Old 11-15-2011, 04:32 AM   #20
IIRC, they were too short. It's been three years, and my memory kind of faded there. I do remember having to run to the parts store for a couple to finish up.
Old 11-15-2011, 09:42 AM   #21
Okay then I can just take two from the donor car
Old 11-17-2011, 07:47 AM   #22
I will also be jumping the neutral saftey switch I never parked my other car in gear so it shouldn't be a problem
Old 11-17-2011, 08:16 AM   #23
Older cars never had them and for the most part they were not needed.
It's one of those safety things that were implemented to protect people from making stupid mistakes, as we all do from time to time. As long as you can remain constantly aware that the car you are about to start has a manual transmission and follow safe starting practices you will be good to go. Always setting the parking brake should protect you as long as it is in good working condition.
Old 11-17-2011, 08:53 AM   #24
Yea it works great lol u thin k u can brief me on wiring the switch it's just finding the two wires and splicing the right there are four on the trans and find which two are the safety switch
Old 11-17-2011, 02:39 PM   #25
Also the trans is coming out of an 87 mustang would that require and extra parts
Old 11-17-2011, 04:42 PM   #26
Shouldnt require any extra parts.
Old 11-17-2011, 04:59 PM   #27
Filibuster
Yeah I forgot to use the alignment tool the first go around...derp!..
And I had a hell of a time gettin the old pilot bearing out!..
XXSTEVEO66 is offline   Reply With Quote
Old 11-17-2011, 06:31 PM   #28
I'm not 100% sure on yours, but I always made a jumper wire with ends on it that plugged into the switch plug of the switch on the clutch pedal arm.
If yours is on the transmission you could do the same and just tape it up good to keep out water. That way if you wanted to put it back you could.
The wires on the transmission are likely to be for your back up lights too.
Old 11-17-2011, 06:48 PM   #29
The safety is on the trans it self it's an automatic there should be 4 wires
---------- Post added at 08:48 PM ---------- Previous post was at 08:47 PM ----------
Isn't the safety switch on the automatic transmissions like in the trans it's self atleast that's the impression.i am under
Old 11-17-2011, 06:50 PM   #30
For future reference:
You can install a clutch disk without an alignment tool if you don't have one handy. Just lightly tighten the pressure plate bolts until the clutch is held into position, but you can still move it with your hands. Then feel all the way around the pressure plate for the clutch and move it until it is roughly the same distance from the edge all the way around. Tighten the pressure plate and you should have it pretty well centered. It's worked for me dozens of times.
To easily remove a pilot bearing, find a punch or cut the threads off of a suitable sized bolt with a long shoulder with a diameter close to the inside diameter of the pilot bearing. Fill the cavity behind the pilot bearing and out to the edge of the pilot bearing with grease. Insert the punch or bolt and give it a few whacks with a large hammer. The pilot bearing should pop right out from the hydraulic force generated.
Might not be a bad idea to hold a rag around the punch or bolt to keep from getting splattered too. If your bolt or punch is too small you can wrap a rag or some tape around it for a better seal.
Old 11-17-2011, 06:52 PM   #31
Yes it is I forgot you were doing a swap.
Let me see if I can find some wiring diagrams so we can be sure to get the right wires.
Old 11-17-2011, 07:02 PM   #32
Filibuster
the grease route was what I did..my prob was finding a punch to fit..i ended up jamin lots of grease soaked paper towel pieces in there so it did the same job just cut down on the grease blowing by..
And I could've gotten away with not using the alignment tool but I already had it and its just that much easier!...well for me atleast!..
---------- Post added at 08:02 PM ---------- Previous post was at 08:01 PM ----------
Have you any pics of this process yet?..id love to see some!..
Old 11-17-2011, 07:53 PM   #33
Here's some info and pics that will help.
AOD to T5 Swap
Name:	5.0 Mustang Ign Diagram.jpg
ID:	34516   Click image for larger version
Name:	5.0 Mustang Manual Trans Neutral_Circuit.jpg
Name:	5.0 Mustang Neutral Saftey & Back up Diagram.JPG
ID:	34518   Click image for larger version
Name:	5.0 Mustang Neutral Safety Jumper.jpg
Old 11-18-2011, 01:06 AM   #34
Okay so what wires got to get jumped for this to work I need colors to colors lol I've bin looking online but no
One has a clear cut way to do it
Old 11-18-2011, 11:08 AM   #35
The picture I posted shows red wires in the dash to the left of the steering column (see the enlarged view to the right of the pic). Just doublecheck to be sure you have the correct wires.
Or you can jumper the wires at the sensor on the transmission I suppose.
Starting my 4.6 to 5.4 prep and swap! Scarreddragon 1996-2004 Mustang GT 36 10-20-2011 10:40 PM
irs to sra swap Black99Snake SVT Mustang 4 08-23-2011 09:41 PM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
whats everyones opinion on starting a 99-04 3.8 thread? cakedout Pre-2005 V6 Mustang 19 07-01-2011 12:21 AM
08:56 PM
