auto trans help - Mustang Evolution
Old 11-09-2011, 07:31 PM   #1
robert3188's Avatar
auto trans help
What do yall think of the performance valve body kit for my aod trans. What's the pros n cons of this over a shift kit. And how baout install? Difficult?
robert3188 is offline   Reply With Quote
Old 11-09-2011, 07:46 PM   #2
deadsp0t's Avatar
Had a shift kit in an AOD and hated it! Mainly cause down shifts were stiff too. I have an EAOD now and a chip to control shift points and firmness
That's unimpressive
Old 11-09-2011, 07:50 PM   #3
Re: auto trans help
That would be nice, but you should rebuild the trans first to ensure it will hold up to the higher pressures and harder shifts.
With all of the different options for valve bodies and shift kits it is difficult to say what the exact pros and cons are.
The main plus for a valve body is that it is professionally built. The shift kit you, a shop or someone else will have to install and if you don't know what you are doing it is easy to ruin a transmission by improper installation. I have personally seen a shop screw up 3 transmissions, just because they were not following proper torquing procedures during assembly.
Installation of a valve body or shift kit I owuld consider to be of medium to hard difficulty and it will require some specialized tools and following the directions VERY carefully and to the letter.
any auto guys wish was manual? wnt2gofst 2011-2014 Mustang GT 39 10-22-2011 03:26 PM
auto shifter cable to steering wheel. Black_Sunshine Pre-2005 V6 Mustang 4 10-02-2011 06:54 AM
dragging with auto? 5.slow At the Track 14 09-11-2011 10:20 AM
Trans Downshift Jolt crkmonzo 1979-1995 Mustang GT 3 08-16-2011 08:35 PM
02:55 PM
