85 shaking stang - Mustang Evolution
Old 11-10-2011, 06:31 PM   #1
juniors's Avatar
85 shaking stang
Hi again next used car prob. Can't quite figure out why the car still shakes. I had the tires balanced. Put new u joints in it. Checked rims 4 out of round. The car came from California 2 Minnesota. This mourning it was 32 degrees outside dame near shook me off the road. Left the ranger plant st Paul it was 45 degrees out didn't shake as bad What next?
juniors is offline   Reply With Quote
Old 11-10-2011, 06:55 PM   #2
Re: 85 shaking stang
Sounds like your tires have flat spots on them that round out more as it gets warmer.
Old 11-10-2011, 07:05 PM   #3
juniors's Avatar
85 shaking stang
Would fixaflatt or some thing else through it out of balance?
Old 11-10-2011, 07:11 PM   #4
Kyle94GT302's Avatar
Fix a flat does and will throw a tire out of balance see it everyday at work!! But what is your problem? i know it's shaking but when does it shake, driving, at idle, etc? If ya were a little more specific I am sure we could help you get the bottom of the problem and a way to fix it!
98 GT- Full PI swap, 93 tune, 3:73 gears,off-road h-pipe,flows, ported plenum and spacer, mac cai, lowered on eibach springs and eibach shocks and struts,spec stage 2 clutch, pro 5.0 shifter
94gt-H,C,I exhaust, eibach suspension--SOLD
Kyle94GT302 is offline   Reply With Quote
Old 11-10-2011, 07:11 PM   #5
juniors's Avatar
85 shaking stang
Sorry forgot dame near new tiers. Maybe say screw them and burn them off?
Old 11-10-2011, 07:14 PM   #6
juniors's Avatar
All the time on & off throttle. driving me nuts.
Old 11-10-2011, 07:18 PM   #7
So only does it when you are on the road doesn't happen when you are just sitting at idle
Old 11-10-2011, 07:26 PM   #8
Yeah, I agree. Flat spots can make it feel out of balance.
Klinton is offline   Reply With Quote
Old 11-10-2011, 07:30 PM   #9
juniors's Avatar
No not at idle gets realy bad at 70mph
Old 11-10-2011, 07:34 PM   #10
Ok well check balance on tires or for any flat spotting or internal separation if the tires are good most likely will be the front wheel/ hub bearings! When they start to go bad they will vibrate the Crap out of the car!
Old 11-10-2011, 07:57 PM   #11
Blogger
99ford's Avatar
^ oh yes does it ever! You mean you don't like to massaged.
Old 11-10-2011, 08:06 PM   #12
Bent rim ,loose driveshaft bolts,or bad u joints can cause this also.
Old 11-10-2011, 08:20 PM   #13
Keep your posts on this subject in this thread, do not make a new one for each reply please.
Wrist watch pics with your stang GTtopgear General Mustang Discussion 64 04-09-2016 08:40 AM
'03 v6 - Issue with violent shaking Tuscloud Pre-2005 V6 Mustang 7 11-14-2011 09:20 AM
trying to get my first stang dcfball91 1979-1995 Mustang GT 6 08-22-2011 08:17 PM
07:15 AM
