95 gt fuel issue - Mustang Evolution
Old 11-13-2011, 09:29 PM   #1
slow_stang's Avatar
95 gt fuel issue
Bought my 95 gt a fe weeks ago and the previous owner said he replaced the fuel pump but when there is a quarter tank or less and I go around a right hand turn it cuts out from fuel loss also if I give it full throttle it acts as if its not getting enough fuel I need help
slow_stang is offline   Reply With Quote
Old 11-13-2011, 09:47 PM   #2
jhagan1980's Avatar
Try replacing fuel filter first. It's cheap and easy to replace.
jhagan1980 is offline   Reply With Quote
Old 11-13-2011, 09:54 PM   #3
slow_stang's Avatar
Ok but would that cause my issue with staving for fuel around turns
Old 11-13-2011, 09:56 PM   #4
jhagan1980's Avatar
I'm not really sure but I would change out the filter before I ever thought about dropping the fuel tank.
Old 11-13-2011, 10:29 PM   #5
slow_stang's Avatar
Will do that tomorrow
Old 11-13-2011, 11:33 PM   #6
Re: 95 gt fuel issue
I wonder if the "sump" panels inside the tank have broken loose or if the pump was installed correctly?
I'd take the tank out, remove the pump and double check everything just to be sure.
Old 11-14-2011, 08:52 AM   #7
slow_stang's Avatar
Ok will do if it is a bad tank what year mustangs can I use
Old 11-14-2011, 09:25 AM   #8
The body style runs from 94-98, but I don't know if the internals are the same on the 96-98 models with the mod motors.
Check on new tanks, they will usually give you a range of what they will fit.
Old 11-14-2011, 09:51 AM   #9
slow_stang's Avatar
Ok thanks a bunch
Old 11-15-2011, 03:05 PM   #10
slow_stang's Avatar
Well I got rid of the high rpm miss but still cuts out on turns I pulled the tank fuel pump is fine and so is the tank I checked for clogging and I checked and cleaned injectors and fpr
Old 11-15-2011, 04:56 PM   #11
Fuel is sloshing away from the tank pickup/fuel sock or a delivery inlet or outlet somewhere in the system. If not the tank or filter, I am at a loss as to where else for you to look. The only cure I suppose is to keep it filled to above the 1/4 tank level.
Old 11-15-2011, 05:01 PM   #12
slow_stang's Avatar
Lol yeah thats what I been doing but the fact that I know I still have the issue bugs the ***** out of me
Old 11-15-2011, 05:03 PM   #13
Highly unlikely but what about a fuel line close to moving parts?like a flexible fuel line close to tie rod getting kinked.I know this is out there but just an idea
Old 11-15-2011, 05:05 PM   #14
slow_stang's Avatar
I checked all the lines
Old 11-15-2011, 09:47 PM   #15
Schlahty's Avatar
Region: Oregon
If you drop your tank-GET a filler tube GASKET. Chances are it will break. It's ford order only. Took me a week and a half to finish my fuel pump cause of that.
Schlahty is offline   Reply With Quote
Old 11-16-2011, 12:41 AM   #16
It almost has to be the baffles in the tank or the sock collapsing.
Old 11-16-2011, 01:53 AM   #17
slow_stang's Avatar
The gasket is good and the baffles were fine and the sock seamed fine also
Old 11-16-2011, 02:04 AM   #18
I believe you, but there just doesn't seem to be anything else that could cause the issue you describe.
Were the pump and suction tube firmly fastened?
Is the tank bent in on the bottom anywheres?
Old 11-16-2011, 02:09 AM   #19
slow_stang's Avatar
They were securely fastened and no dents its got me boggled
Old 11-16-2011, 02:15 AM   #20
Me too.
I'll keep my eyes and ears open for a solution for you.
Maybe something will turn up soon.
Old 11-16-2011, 02:17 AM   #21
slow_stang's Avatar
Thanks a ton man for all the help
Old 11-16-2011, 02:33 AM   #22
You are welcome.
Old 11-16-2011, 06:20 AM   #23
If everything TH said. Checks out is has to be bad/loose fuel pump or relay wiring.
2004 GT 315 Tire Rubbing Issue TheJigShow 1996-2004 Mustang GT 11 11-13-2011 08:31 AM
95 gt fuel tank?s mustangbill00 1979-1995 Mustang GT 1 10-12-2011 11:09 PM
92 GT having fuel issues when hot ? ebourd 1979-1995 Mustang GT 7 09-23-2011 10:53 PM
Mustang GT Fuel Injector 504 Stang Rida 1996-2004 Mustang GT 4 09-01-2011 10:12 PM
Fuel gauge issue macmarine39 1979-1995 Mustang GT 7 07-16-2011 06:19 PM
03:49 AM
