Rear main seal replacement? - Mustang Evolution
Old 11-17-2011, 09:30 PM   #1
90Stang_5.0's Avatar
So i was replacing all the gaskets on my 302....i was gunna go ahead and replace the rear main seal but im not to sure on how to....am i supposed to remove the crank or the seal holdin the cranks down or can it be done strait out tha bak? Help me out
90Stang_5.0 is offline   Reply With Quote
Old 11-17-2011, 09:43 PM   #2
Brett Greene's Avatar
Straight out the back homes
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 11-17-2011, 09:54 PM   #3
5.0 ferntown's Avatar
Region: New Mexico
Yeah it's probably best to take it out from the back if the engines out.
5.0 ferntown is offline   Reply With Quote
Old 11-17-2011, 11:27 PM   #4
Got tha block out nd took tha flywheel off....i see tha seal but is there a way or technique to get tha seal out without having to pry it nd risk damaging tha crank snout?
Old 11-18-2011, 04:36 AM   #5
SleepingStang's Avatar
Take a small diameter sheet metal screw and thread it into the seal, not too far though. Then just use a small crow bar or pliers and pry it out.
SleepingStang is offline   Reply With Quote
Old 11-18-2011, 11:54 AM   #6
jwhayne0001's Avatar
They make a seal puller, i think lisle makes it, got mine from sears, 10 bucks
jwhayne0001 is offline   Reply With Quote
Old 11-18-2011, 12:03 PM   #7
stampde's Avatar
Re: Rear main seal replacement?
when you replace it put some grease on the onside lip ( the part that rides on the crank ) if you start it up dry it'll sometimes wipe the seal out .........
2011 GT Auto
Old 11-18-2011, 01:48 PM   #8
Also apply grease to the spring around the seal to help hold it in
Old 11-18-2011, 01:50 PM   #9
And here's that puller
Rear main seal jhagan1980 General Mustang Discussion 0 11-04-2011 07:09 AM
'98 GT, BEST rear sway bar replacement? stallion98 1996-2004 Mustang GT 5 10-09-2011 08:35 PM
Rear end swap bmabbott Pre-2005 V6 Mustang 9 10-01-2011 12:14 AM
Rear brakes tubing tbonestang 1979-1995 Mustang GT 5 09-01-2011 10:14 PM
03 Stang Rear Blacked Out!? stangiusmaximus Mustang Paint, Appearance & Detailing 4 08-29-2011 06:30 AM
09:12 AM
