Mis once warmed up - Mustang Evolution
Old 11-18-2011, 06:38 AM   #1
Chefnick's Avatar
Mis once warmed up
Know you have all heard this before but I'm trying one last time before I bring it in to someone. This has got me going crazy.
The car runs as smooth as a new car when it is cold and has not fully warmed up. Once the car is warm, it runs ruff. It's hard to explain but it seems like it is bogging down. Kindof sounds And runs like it would If you shift to a Higher gear to soon if that makes sence. But it runs like that all the way threw 4 th and 5 th. It runs a bit better in higher rpms but at lower rpms it's not great.
It's got new plugs, wires, tps, icm, fuel pressure regulator, fuel filter, distributer, cap and rotor. Any other thoughts to try. It also is running rich. I want to think it is a fuel issuer but I'm not sure. Thanks for the help.
Chefnick is offline   Reply With Quote
Old 11-19-2011, 05:31 PM   #2
Sounds maybe like timing.
Old 11-19-2011, 08:53 PM   #3
Ilovemustangs88's Avatar
My 2000 mustang does that too. In low gears it hesitates to shift and sometimes when driving you hit the gas and nothing happens and I have had to coast to pull over til it wanted to go again. But sometimes it shifts slow and shifts hard. Mine is an automatic
Ilovemustangs88 is offline   Reply With Quote
Old 11-19-2011, 10:11 PM   #4
Chefnick's Avatar
If anyone has the same problem and reads this I just want to tell them what it was. It was the o-rings on the injectors. Pulled them all off, changed the rings and she runs like new. Also adjusted the timing a bit after.
Old 11-20-2011, 08:09 AM   #5
I'm going to try that thanks
Old 11-20-2011, 11:26 AM   #6
Re: Mis once warmed up
Congratulations on finding and curing your issue.
That was a difficult one and you managed to find and fix it.
Old 11-20-2011, 11:27 AM   #7
If that doesn't help your issue, just post up you problems in another thread and we'll do our best in trying to help you sort it out.
Old 11-21-2011, 04:37 PM   #8
My mustang is going to the garage Friday I'll post what it turns out to be!
Old 11-21-2011, 04:53 PM   #9
Furious35's Avatar
Region: Arkansas
I can almost garuntee it's your o2 sensors. What happens is the ECM uses a default program or bin files what we call a closed loop where it doesn't use any sensors for air fuel timming ect. It uses pre programed fuel maps ect. Therefore running normal until it reaches 170 degrees. Now once warmed up it relies on sensors 94-94 sn95 cars primarly use O2s. For air/fuel they due use IAT MAF TPS ECT but most the time O2s are to blame for rich running condition. Hope this helps
Furious35 is offline   Reply With Quote
Mis Chefnick 1979-1995 Mustang GT 11 11-20-2011 08:06 PM
08:22 PM
