84 t5 in my 93 will it work - Mustang Evolution
Old 11-18-2011, 04:56 PM   #1
04machazblue's Avatar
Okay so I know this may be dumb to some but would I still be able to use this trans in a swap
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 11-18-2011, 05:11 PM   #2
93slowstang's Avatar
Yes but the torque ratings are low for that one.
---------- Post added at 06:11 PM ---------- Previous post was at 06:09 PM ----------
Also it does not use the same fluid as a world class.
Old 11-18-2011, 08:13 PM   #3
aegischief's Avatar
It'll work but its not rated to handle the power of even a stock '93 5.0 due to the weak input shaft on those first Gen t5's. The gearing is also different which doesnt really matter. Bottom line, it will work, just don't abuse it.
aegischief is offline   Reply With Quote
Auto to Manual. What will work? MustangGT02 1996-2004 Mustang GT 9 10-14-2011 06:10 AM
Will this work? Qwik Four Six 1979-1995 Mustang GT 7 10-09-2011 06:51 AM
Left low beam headlight wont work but i will when i turn on high beams p1blake04 1996-2004 Mustang GT 4 09-05-2011 10:30 PM
Few cars I've worked on at work. Otlaw80 Pictures and Videos 8 09-02-2011 07:14 PM
Will a 6 cylinder C4 work with a 289 Tuch65 Classic Mustangs 2 08-11-2011 05:13 AM
01:47 PM
