Oil in upper intake? - Mustang Evolution
Old 11-19-2011, 11:37 AM   #1
5.8GT's Avatar
I took my upper intake off today and it has oil in it, any suggestions?
5.8GT is offline   Reply With Quote
Old 11-19-2011, 12:41 PM   #2
jwhayne0001's Avatar
Sounds like rings are allowing for blow by
jwhayne0001 is offline   Reply With Quote
Old 11-19-2011, 12:42 PM   #3
I read something about this on another forum one time.the dude had a Holley systemmax setup.and ended up having to relocate the PCV valve to a different location.I believe right under the upper intake by the fuel rail.he said he had to make an 90* adapter cause it was a tight fit.someone told him he was getting blow by cause where it was placed had to high of vacuum.so relocating it reduced the vacuum and blow by.
I'm not sure if this has anything to do with you or how much sense it makes but just thought I would share.
Old 11-19-2011, 02:42 PM   #4
Re: Oil in upper intake?
A light coat of oil is fairly normal.
You might want to clean or replace the pcv valve and screen.
They may be saturated to where they are passing more oil than normal.
If it is a heavy accumulation of oil then you may have excessive blowby from worn out piston rings as stated above. You could do a compression test to see if that is your problem.
Old 11-19-2011, 06:53 PM   #5
SSC182's Avatar
If you think your having blow by conduct a compression test and if you have low readings get a cylinder leak down test which will tell you what the problem is
SSC182 is offline   Reply With Quote
Old 11-19-2011, 11:28 PM   #6
5.8GT's Avatar
Thanks I will check it out!
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
93 Cobra upper intake bolts Chefnick 1979-1995 Mustang GT 8 11-07-2011 08:38 PM
Oil pressure issues Klinton 1979-1995 Mustang GT 6 09-11-2011 01:52 PM
Off Topic Question - Oil Weight illestdomer2005 Pre-2005 V6 Mustang 7 09-09-2011 09:26 AM
What oil should be used on my cam break in? wc3john 1979-1995 Mustang GT 6 08-14-2011 11:43 PM
01:37 PM
